9
Oneplus 5 Battery drain problem
  1. Rituraj Mishra
    Froyo Jun 23, 2017
    Rituraj Mishra , Jun 23, 2017 :
    I just bought a oneplus 5 and the moment I connected it to the wifi, there was an update!
    I downloaded it and updated my phone.
    The thing is the battery life is not really good!
    I mean there are some touch latency drawbacks too.
  2. ganeshknr
    Ice Cream Sandwich Jun 23, 2017
  3. Rituraj Mishra
    Froyo Jun 23, 2017
    abhishek28609 likes this.
  4. samuelchan727
    Gingerbread Jun 23, 2017
    Peshyy, ajshanker and abhishek28609 like this.
  5. DarkExistence
    DarkExistence , Jun 23, 2017 :
    don't know, just reached 6hrs here, still on the first charge and it was dozing overnight etc. so was a lot of testing camera, screen brightness, setting the phone up, connecting to android wear, bad signal area etc. I'm happy with mine
    niijonodhg and Predict23 like this.
  6. F_Daniel_Tiny_Turner_Hcb
  7. LCOSTA17
    LCOSTA17 , Jun 23, 2017 :
    you are accessing the battery duration, based on one day???
    and with app installation and soft. updates.
    you're serious!!!!!???
  8. nageshwaran.k
    Froyo Jun 23, 2017
  9. spencerb12
    Donut Jun 23, 2017
  10. _DEDSEC_
    Jelly Bean Jun 23, 2017
    _DEDSEC_ , Jun 23, 2017 :
    Finely the first battery drain thread for the One Plus 5, what would we do without you.
  11. F_Junaid_Khan_kKSE
    Honeycomb Jun 23, 2017
  12. roblessed
    Cupcake Jun 23, 2017
    roblessed , Jun 23, 2017 :
    Can't believe the battery drain thread is already alive. I feel the people who report this are people excessively using their brand new phone. It's not a zerolemon battery honey. From others post in this thread it seems they are doing just fine with the battery. OP may just need to dial back excitement a tad bit and let the phone sit lol. Wiping cache does tend to help after updates as well.
  13. Saurav Pillai
    malidan likes this.
  14. [GG]
    [GG] , Jun 23, 2017 :
    Apparently he's serious enough to start a thread about it.
    Y27 likes this.
  15. Waka_Yama
    Waka_Yama , Jun 23, 2017 :
    @Rituraj Mishra
    Okay, did you configure all energy-settings properly? If so then perform the basic "solve everything" solution:
    Clear Chache, if this doen't help check if one app is running bogus. Doesn't help? Factory Reset! Doesn't help? Flash Again! Doesn't help? Contact support / RMA / Husslefree Warrenty.....
  16. Ludo_Mansio
  17. Superbrowndude
    Superbrowndude , Jun 23, 2017 :
    This is the 3rd day with my phone and have been fortunate enough to not have any battery drain issues
    G_Christopher_Hovell_ukX and Y27 like this.
  18. afr0dactyl
  19. smieciokop
    Donut Jun 23, 2017
  20. malidan
    Nougat Jun 23, 2017
    malidan , Jun 23, 2017 :
    Why should he need to config all energy settings( whatever that is) it a brand spanking new phone.
