9
Oneplus 5 Battery drain problem
  1. malidan
    Nougat Jun 23, 2017
    malidan , Jun 23, 2017 :
    Why? The device I have did
    8hr
    8hr
    7hr
    Out the box on the first 3 charge cycles, I posted them on the forum.
    You don't sound too confident, so far
  2. jayanyway
    US Brand Ambassador Jun 23, 2017
  3. Waka_Yama
    Ice Cream Sandwich Jun 23, 2017
    Waka_Yama , Jun 23, 2017 :
    I meant the Battery optimization settings, Turning doze on / off.
    why? because nobody knows what he has done.
    what he has done? I think perform an update, so we have enough of people around faceing problems after updates. so take a look if everything is like it should be, even the settings.
  4. FTAFreedom
    Gingerbread Jun 23, 2017
  5. malidan
    Nougat Jun 23, 2017
    There is not much you can do in the setting to make the battery drain like that, the update has a bug or it has broken a process.
    Your suggestion to wipe the cache is good one and hopefully that resolves his issue, if not he will have an interesting few days as I don't believe there is a factory image out yet.
  6. Rituraj Mishra
    Froyo Jun 23, 2017
    Rituraj Mishra , Jun 23, 2017 :
    Firstly,
    I have cleared cache of the device from the recovery mode.
    I am not using my phone heavily. I too had oneplus 3 before soo, i know how it WORKS.
    Secondly,
    People there who think this post was useless and should be deleted, why did you just made it more useless with your helpful comments?
    Thirdly,
    I posted this because battery was my concern, and it is degrading quite rapidly with my device. AND IF I SAY SO, PLEASE DO TRUST ME!
    AND THANKS TO EVERYONE WHO ACTUALLY HELPED BY SUGGESTING.
  7. Rituraj Mishra
    Froyo Jun 23, 2017
    Firstly,
    Secondly,
    Thirdly,
  8. SimonRam
    Lollipop Jun 23, 2017
    SimonRam , Jun 23, 2017 :
    What we need is some Jio and voLTE issues and we have a great groundhog day.
  9. qbix088
    Donut Jun 23, 2017
    qbix088 , Jun 23, 2017 :
    Im not experiencing any battery drain use so far. I had 6hrs screen on time with 21% battery remaining after a full charge.
    thomaserrol likes this.
  10. codecharger
    Donut Jun 23, 2017
    codecharger , Jun 23, 2017 :
    Not got mine yet, but if I can go into work for weekend overtime and listen to 8.5 hours of non-stop music, 0.5 hours of which is bluetooth connection to my cars media center and still have battery life to spare as I do with my 3T then I will be well pleased.
  11. ravsrav
    Eclair Jun 23, 2017
    ravsrav , Jun 23, 2017 :
    You might be able to clear cache and/or reset to factory settings and this may help
    Rituraj Mishra likes this.
  12. toastytoast1234
    Marshmallow Jun 23, 2017
    toastytoast1234 , Jun 23, 2017 :
    Does it have a built-in call recorder?
    Dunnow, Rituraj Mishra and SimonRam like this.
  13. Max279
    Cupcake Jun 23, 2017
    Max279 , Jun 23, 2017 :
    i don't have the problem but i have a diverent problemen i doesn't connect with lte network
  14. Charles2388
    Froyo Jun 23, 2017
    Charles2388 , Jun 23, 2017 :
    factory reset, discharge till zero, turn it off, charge it to 100
    return the phone if problem persists
  15. apollonolive
    Honeycomb Jun 23, 2017
  16. Rituraj Mishra
    Froyo Jun 23, 2017
  17. SRVisGod24
    Honeycomb Jun 24, 2017
  18. pathankp
    Cupcake Jun 24, 2017
    #38
  19. torbell
    #39
  20. SJBoss
    Lollipop Jun 24, 2017
    SJBoss , Jun 24, 2017 :
    beat me to it [e]1f602[/e][e]1f602[/e]
    #40
