9
Oneplus 5 Battery drain problem
  1. ShahryarShadani
    Cupcake Jul 3, 2017
    #61
  2. Waka_Yama
    Ice Cream Sandwich Jul 3, 2017
    Waka_Yama , Jul 3, 2017 :
    yes, should.... ;)
    #62
  3. apurav799
    Froyo Jul 3, 2017
    #63
  4. TugaPower
    Jelly Bean Jul 3, 2017
    #64
    theshinybeast likes this.
  5. expatCanuck
    Eclair Jul 3, 2017
    expatCanuck , Jul 3, 2017 :
    Got mine on Friday. Charged it fully. Used it sporadically over the weekend. It dropped below 20% this morning (Monday), and I charged it up to 85% in about a half-hour.
    Certainly no complaints here (and a significant improvement over the Nexus 5 that the OnePlus 5 is replacing).
    #65
  6. BooBzi
    Gingerbread Jul 3, 2017
    BooBzi , Jul 3, 2017 :
    Can you provide more detailed battery stats? Also try using gsam application to get more info on draining apps!
    #66
  7. edkensington
    Donut Jul 3, 2017
    edkensington , Jul 3, 2017 :
    Try turning off the active scanning on Bluetooth and wifi. The Bluetooth was draining my battery before I turned that off
    #67
  8. jishii
    Cupcake Jul 6, 2017
    jishii , Jul 6, 2017 :
    TypeApp accessing two Gmail accounts caused my battery to drain at a very rapid rate. Moved one over to another email app and now I'm back to a decent 21 hours on a full charge. :)
    #68
  9. anshul@1987
    Cupcake Jul 17, 2017
    anshul@1987 , Jul 17, 2017 :
    my oneplus 5 which i bought on 23 june working very good till yesterday but suddenly phone started constantly heating up and also battery is draining fast, with in 2 hours 30% of battery drained out and while last night i plugged out phone from charging after completing 100% phone completely drained out with in 4 hours and switched off.
    battery is draining very fast, I optimised the app's in battery menu and also rebooted and reset the phone but still problem is there, what to do????
    #69
  10. anshul@1987
    #70
  11. brandaopj
    Gingerbread Jul 17, 2017
    #71
  12. krishnalonely
    Eclair Jul 17, 2017
    #72
  13. irkvr
    Donut Jul 17, 2017
    #73
  14. kenny1_91
    Cupcake Jul 21, 2017
    kenny1_91 , Jul 21, 2017 :
    Hi Mate, How do I access the file? Is "enter files" under “oneplus Logkit”?
    #74
  15. Crystal Z.
    Global Community <3 Staff Member Jul 22, 2017
    Crystal Z. , Jul 22, 2017 :
    Sorry, it's file manager-oem log, zip the whole oem log and share it to us.
    Thank you for your time.
    #75
  16. r0drlgo
    Eclair Jul 29, 2017
    #76
  17. clio24v
    Cupcake Jul 31, 2017
    clio24v , Jul 31, 2017 :
    How long battery keep alive in your Op5 6gb 64gb. I have problem with draining. Phone was not using so much.First time battery keep alive only one day screen on time was terrible,then i sent phone to the service. They change the battery and now it took 2 days to empty but that is strange because on my Op5 8gb 128gb with more usage it took 3 days to empty and i have screen on time about 5 hours. Does anybody have the same problem. Thanks for your answers.
    #77
  18. niekschoemaker
    Cupcake Aug 1, 2017
    niekschoemaker , Aug 1, 2017 :
    2 hours of screen time, used navigation for 1 hour and listened to music for 4 hours, that's pretty good if you ask me
    #78
  19. Manas_Mishra_1989
    Ice Cream Sandwich Aug 1, 2017
    Manas_Mishra_1989 , Aug 1, 2017 :
    Just give it some time, you will see on 4-5th charge cycle it will get better.
    Also try many tips on a Mega thread on battery in community.
    Charge your phon when it reaches 30% upto 90% dont let it dry out then charge to full.
    I have experienced what you are now and had posted bout it too but after trying the tips and let the phone take its time it works nicely now.
    By the way OTA updates eat battery a lot so don't worry its not unusual.
    Check out my charge cycle and bat stat.
    #79
  20. steviecoupland
    Cupcake Aug 6, 2017
    steviecoupland , Aug 6, 2017 :
    Mine was the same straight out the box. I tried to use it for 2 days, I was getting 4hrs to a full charge and that was it on standby not using the phone at all. I have returned it to them for a replacement
    #80
