5
OnePlus 5 battery drain
  1. Oneplus_5_user
    Eclair Jul 1, 2018
    Oneplus_5_user , Jul 1, 2018 :
    I have noticed that my op5 is not holding charge like it usually does. I usually charge immediately after i woke up and even with heavy usage of 2-3 hrs of constant hotspot, my phone retains charge and goes upto 24hrs without next charge. But for a past few days charge is draining a bit faster than usual. Anyone know what is causing this and also, anyone facing the same issue?
  2. Budruel
    KitKat Jul 1, 2018
    Budruel , Jul 1, 2018 :
    Obviously you have not searched the forum. It is what you must do. Read the mega thread about battery.
  3. satishsaragula
    Donut Jul 1, 2018
  4. G_T_Bennett
    Jelly Bean Jul 1, 2018
  5. Kuldeepwith1+
    Cupcake Aug 8, 2018
  6. pancham1174@gmai
    Cupcake Aug 8, 2018
  7. Yashvendra_Singh_Raghav
    Ice Cream Sandwich Aug 8, 2018
  8. Yashvendra_Singh_Raghav
    Yashvendra_Singh_Raghav , Aug 8, 2018 :
    the time ur talking about is .. estimated time.
    which may change any time... depends upon usage of an individual.
    if u use moderatly..then after 10 percentage .... of drain
    phone will show.. 21hours remaining... like that.
    that doesn't mean ur phone will definitely last for 21 hours it may last for... 15hours or it may last for more then 21hours.
    depends how u use.
    screenshot is given beliw so u can get it clearly
  9. meOne
    Cupcake Oct 18, 2018
    meOne , Oct 18, 2018 :
    same problem here. running the latest updates on op5. this was not an issue until recently. battery settings say Android system is consuming 30% of battery. not sure if this is normal, but it also feels warmer than usual in the back of the phone. I am not a techy person. all I know is that I use to be able to go the whole day and still have more than 30% and I haven't changed the way I use my phone or installed any new apps. btw, this didn't take me long at all to type and my battery went down 2% in that time. definitely not normal.
    K1517564220968 likes this.
  10. Waveform Modifier
    Marshmallow Oct 18, 2018
    Waveform Modifier , Oct 18, 2018 :
    Please visit the pinned battery post.
    borft and Deactivated User like this.
  11. karkimilan
    karkimilan , Oct 18, 2018 :
    same thing happened with me,,clear the cache from recovery after that everything went back to normal
    borft likes this.
