OnePlus 5 Bluetooth issue
  1. tusharpatil02
    Cupcake Jul 20, 2017
    tusharpatil02 , Jul 20, 2017 :
    Hello I bought OP5 on the very first day and I'm pretty much happy with it.. but somehow its not able to detect my Samsung Level U Bluetooth headphones... rest all the phones are able to detect it. only issue is with OnePlus..
    is it a bug? need help...
  2. mohan9275
    Gingerbread Jul 20, 2017
  3. F_Yannick_Sans_aYOl
    Froyo Jul 20, 2017
    F_Yannick_Sans_aYOl , Jul 20, 2017 :
    maybe you need first to disconnect your Samsung before trying to connect to the op5.
    my OP5 works fine with all my devices even in my car
    Brian Poole likes this.
  4. begbie69
    Donut Jul 20, 2017
  5. F_Yannick_Sans_aYOl
    Froyo Jul 20, 2017
  6. dud2stud
    Eclair Jul 20, 2017
    Best Answer
    dud2stud , Jul 20, 2017 :
    hold on the power button for seven seconds with your Samsung level U until OP5 recognize it and you're good to connect. I had the same issue with Sony mdr1000x headphone.
    keithnyc likes this.
  7. brian1900
    brian1900 , Jul 20, 2017 :
    Had some problem while connecting to my boss as well. Don't figure out how oneplus5 works. New to oneplus
  8. tusharpatil02
    Cupcake Jul 22, 2017
    tusharpatil02 , Jul 22, 2017 :
    tried... not working
  9. keithnyc
    Moderator Moderator Jul 25, 2017
    keithnyc , Jul 25, 2017 :
    Dude, you're a genius! I was having the same problem with pairing my QY7 bluetooth headphones with my OP5 (which were immediately detected by my OP3t). So I pressed the power button on the headphones and held it down (even after it said "power on"), and all of a sudden the headphones said "pairing" and "QY7" suddenly appeared under paired devices on the OP5!
    Thanks again, mate
    dud2stud likes this.
  10. carlos.estepa
    Eclair Aug 11, 2017
    carlos.estepa , Aug 11, 2017 :
    I'm using the Samsung Level U since the first day I got my OP5, it connects to them with the easy steps explained in this thread, however I'm experiencing some noise when using them outside (street, park, mall), can this be due to Wifi interference in the 2.4 GHz band?
  11. X1539462225895
    Cupcake Oct 15, 2018
    X1539462225895 , Oct 15, 2018 :
    You have to pair the Samsung Level U headset first with your OP6. To do that you need to power on Level U while holding the Multifunction/Talk button for about 5 seconds. You should see the LED alternating between blue and red. And then on your OP6 your Samsung Level you will appear in the available devices list. You will be able to connect the headset after it has been paired successfully.
