96
Oneplus 5 Camera Now For Oneplus 3/t
  1. ashacekar
    Ice Cream Sandwich Jul 21, 2017
    ashacekar , Jul 21, 2017 :
    It is not possible at the moment.As i can't do much modifications in cloned app.The original app can't be edited so i can't add extra features.
  2. gautamgzb2
    Donut Jul 21, 2017
    gautamgzb2 , Jul 21, 2017 :
    Ok sir. thanks no problem for flash capturing i use op3 camera
    thanks for reply and suggestions
    ashacekar likes this.
  3. Joeltj
    Eclair Jul 21, 2017
    Joeltj , Jul 21, 2017 :
    OnePlus gallery is too lag and getting crashed
  4. ashacekar
    Update it to latest version by going to apkmirror website.It's a bit laggy but does not crash.
  5. AcmE85
    AcmE85 , Jul 21, 2017 :
    I tried version 5 on OOS Beta 20
    - HQ does not work (no postprocessing)
    - HDR not available
    - auto-mode has worse quality than the stock OOS 1.4 camera app
    The "port" also messes with the stock camera app while installed.
    - HQ does not apply any postprocessing at all -> more noise
    Deinstalling the port "fixed" the postprocessing on the stock camera v1.4,
    but it showed "processing" in the foreground until I restarted my device.
    Deactivated User likes this.
  6. ashacekar
    Thx for ur review
  7. G_Nits_Beast_UERu
    Cupcake Jul 21, 2017
    G_Nits_Beast_UERu , Jul 21, 2017 :
    I am unable to open youtube app in my 3T on wifi but on mobile data everything working fine. On wifi everything working fine too except youtube app. Its just keep loading and never opening although the network speed is quite good.
    I tried clearing cache and data of youtube app still with no luck.
    Can anyone please help in this.
  8. ashacekar
    U can create a thread in that regard.
  9. Sun90
    Starting Point Expert Community Expert Jul 21, 2017
    Sun90 , Jul 21, 2017 :
    He has already done that ,after posting that issue every where.;)
    Deactivated User and ashacekar like this.
  10. F_Suresh_Bangla_pauz
    Froyo Jul 21, 2017
    F_Suresh_Bangla_pauz , Jul 21, 2017 :
    hey. do factory reset... if it worked fine... if it is not worked do flash g apps
  11. drbihagkv
    Froyo Jul 21, 2017
  12. G_Omar_Jabak_CBRn
  13. filippo3d
  14. yogaraj419
    Eclair Jul 22, 2017
  15. Mohit_47
    Jelly Bean Jul 22, 2017
    Mohit_47 , Jul 22, 2017 :
    There is no 1080p 60fps option + app laggs + no hdr mode
    only 2x zoom comes handy
  16. ashacekar
    Ice Cream Sandwich Jul 22, 2017
    ashacekar , Jul 22, 2017 :
    Download the latest oneplus gallery app from apkmirror website
  17. jitendrasr34
    Gingerbread Jul 22, 2017
  18. G_srikanth_n_Reddy_uBRJ
    Cupcake Jul 22, 2017
  19. yogaraj419
    Eclair Jul 22, 2017
    yogaraj419 , Jul 22, 2017 :
    it was crushing bro
  20. ashacekar
    In a cloned app, i can only replace or add files.But can't add or edit features.Original app can't be edited.
