2
oneplus 5 camera problem!
  1. G_sharma+
    Donut Jul 6, 2017
    G_sharma+ , Jul 6, 2017 :
    because you are increasing the brightness so the bars are disappearing you shold slide it down to reduce brightness and bars will appear.
  2. Blackhat7170
    Donut Jul 7, 2017
    Triforce likes this.
  3. blake_2048
    Cupcake Jul 9, 2017
    blake_2048 , Jul 9, 2017 :
    in that case, it's normal. This happens when the lights refresh rate and the shutter speed match up. It's normal and happens to every camera under certain conditions.
    Blackhat7170 likes this.
  4. Blackhat7170
    Donut Jul 9, 2017
    Blackhat7170 , Jul 9, 2017 :
    ok thanks man. I got some pretty good pics out of it so far so everything seems fine. thanks again
  5. F_Matthew_Robinson_HHtQ
    Cupcake Jul 9, 2017
    F_Matthew_Robinson_HHtQ , Jul 9, 2017 :
    Yep, as others have said, it's just a strange effect caused by the pulse rate of the light and the refresh rate of the camera, it happens to most digital cameras.
    the reason you feel a "vibration" when tapping the phone is because your phone has autofocus tech. a tiny motor moves the lens slightly to adjust focus. the "vibration" is just the internals of the lens moving slightly. don't worry, that's normal! in fact, I'd only be worried if my phone *didn't* do that when tapped anywhere near the lens :)
  6. Drakula01
    Eclair Jul 9, 2017
  7. anujgkhr
    Cupcake Jul 9, 2017
    anujgkhr , Jul 9, 2017 :
    PLEASE HELP IMPORTANT... does eis on 1080 60fps dont work on op5 ? and can u notice high noise in video recording if u record it in silent place with no sound like in a quiet room?
  8. sharathrajuk
    Cupcake Jul 14, 2017
    sharathrajuk , Jul 14, 2017 :
    can someone please help me to resolve the op5 camera shutter sound issue. shutter sound is coming while taking photos even disabled the shutter sound option.
  9. F_Deepak_Kumar_Modi_QrjO
  10. hparulkar
    Froyo Jul 21, 2017
    hparulkar , Jul 21, 2017 :
    Why do you want to hijack someone else thread on different topic. What is stopping you to create new thread.
  11. hparulkar
    Froyo Jul 21, 2017
    Did u ever got solution to this problem as I am also facing the same issue. Not sure if its h/w or S/w issue
  12. InnerDragon103
    Cupcake Sep 15, 2017
    InnerDragon103 , Sep 15, 2017 :
    Dude you nailed it! I just noticed the same frequency aliasing issue when I tried taking a photo under compact fluorescent lights, and it went away when I took a photo outside. Thanks for clarifying that - thought my 2 day old OP5 was giving issues... *whew*
    olavojunior likes this.
  13. olavojunior
    Eclair Dec 1, 2017
