OnePlus 5 encryption
  1. ibbe96
    Froyo Jun 22, 2017
  2. fommuz
    Gingerbread Jun 22, 2017
    nadim77389 and ibbe96 like this.
  3. ganeshknr
    Ice Cream Sandwich Jun 22, 2017
    ganeshknr , Jun 22, 2017 :
    Most phones don't come encrypted. One would have to manually do it from security settings.
  4. fommuz
    fommuz , Jun 22, 2017 :
    However, OnePlus is encrypted. A friend of mine has the OnePlus 5 since yesterday.
    ibbe96 likes this.
  5. ibbe96
    Froyo Jun 22, 2017
    ibbe96 , Jun 22, 2017 :
    what kind of encryptions is it and how secure is it
  6. ganeshknr
    Is the device encrypted from start?o_O
  7. Simon1816
    Simon1816 , Jun 22, 2017 :
    Yes, like every other phones with Android 6 and above.
    ganeshknr likes this.
  8. ganeshknr
    Wouldn't that hinder the performance of the device?
  9. Simon1816
    It does cause a performance decrease, but I think it's possible to disable it, if you want to get the full performance.
  10. ganeshknr
    That would be to factory reset the device again. There is no option to click on decrypt in the security settings.
  11. MaxSayre
    Honeycomb Jun 22, 2017
    MaxSayre , Jun 22, 2017 :
    Yes, it does. I can confirm with a screenshot if necessary.
    The performance hit is minimal. 3-4% at the most. You're more likely to benefit from your phone being encrypted if it's lost than noticing the performance increase from unencrypting it.
    lostLambda and ganeshknr like this.
  12. Simon1816
    I don't thinks that will help, if I remember correctly you need to install third-party software.
  13. Ensar
    Donut Jun 22, 2017
    Ensar , Jun 22, 2017 :
    Let me ge this straight;
    Oneplus 5 has encryption - but do you need to enable it or is it already enabled? If it's enabled then can you disable it?
    Do you guys also know what kind of encryption it is & how secure it is?
  14. ganeshknr
    Modifying the kernel might help.
  15. MaxSayre
    The process for removing encryption in Android is to wipe the phone. This is for security.
    I'm not sure how this makes sense? I guess if you made a custom ROM that supported decryption you could... but I haven't seen that feature in any ROMs. Even custom ones.
  16. Simon1816
    It's encrypted from the start. It can't be disabled easily, and I will not recommend it, the benefits of encryption is far greater than the performance benefit. It's encrypted with a 128-bit AES master key, which is then encrypted with your password and a salt.
    Ensar and ibbe96 like this.
  17. ganeshknr
    Not sure. I'll try doing some research on this. Thanks
  18. ibbe96
    Froyo Jun 22, 2017
    can you please take a picture
  19. Ensar
    Donut Jun 22, 2017
    Thank you for the information. It's amazing how fast OP5 boots up and works with encryption pre-activated.
    ibbe96 likes this.
  20. MaxSayre
    At the bottom.
    Edit: For what it's worth, the menus are initially white and I've changed the phone to the dark theme.
    ganeshknr and ibbe96 like this.
