10
OnePlus 5 - Freedom Mobile (Wind) - 4G/LTE
  1. SWM2
    Eclair Jul 20, 2018
    SWM2 , Jul 20, 2018 :
    I registered as well a few days ago and it took a couple hours to receive the text but it finally came. I am hoping once you register that the work around that others have tried will work for us .
  2. astracd
    Gingerbread Jul 20, 2018
    astracd , Jul 20, 2018 :
    I will try again today. As I did it last night and nothing come yet.
    BTW It takes forever to login
  3. astracd
  4. astracd
    I tested shaw / freedom hotspot... Still not getting wifi calling.
    Finally got logged in my account and set wifi calling again.
  5. astracd
  6. gillau
    Eclair Jul 20, 2018
  7. astracd
    Outside 80% of time - Alberta.
    This start happening from moment I switch to Volte_OEM_Lab. Before I never had +
  8. MILKY@143
    Eclair Jul 21, 2018
    MILKY@143 , Jul 21, 2018 :
    Bro. how the possible LTE+ signal can you explain. I am using OnePlus 5t explain bro. I set the preferred network TD-SCDMA -WCDMA-UMTS after this settings few minutes showing 4g signal at home then automatically changing the signal available network like 3g. Can you tell me how set the preferred network LTE+.
    Thank you.
  9. gillau
    Eclair Jul 21, 2018
    gillau , Jul 21, 2018 :
    I get consistent 4G, not 4G+ in Toronto. mine is set at LTE/TD-SCDMA/UMTS
  10. astracd
    Gingerbread Jul 21, 2018
    astracd , Jul 21, 2018 :
    This is what I did and I got 4G+
    https://forum.xda-developers.com/oneplus-5t/how-to/guide-volte-vowifi-german-carriers-t3817542
    Pick Volte_OEM_Lab
  11. astracd
    I did not get text yet. :/
  12. astracd
    Gingerbread Jul 23, 2018
    astracd , Jul 23, 2018 :
    still not getting that msg... If I text SIM to 40001 or Setup to 41111 I get msg's back.
    BTW found on reddit that apn is different for wifi calling so I update that as well, but nothing changed.
    So annoying.
    apncarrier="VoLTE"
    mcc="302"
    mnc="490"
    apn="volte.mobilefrdm.ca"
    type="ims"
    protocol="IPV4V6"
    user_visible="false"
    apncarrier="E911"
    mcc="302"
    mnc="490"
    apn="e911.mobilefrdm.ca"
    type="emergency"
    protocol="IPV4V6"
  13. SWM2
    Eclair Jul 25, 2018
    SWM2 , Jul 25, 2018 :
    Any luck yet on the activation text?
  14. astracd
    Gingerbread Jul 25, 2018
    astracd , Jul 25, 2018 :
    No. I email customer support to see what a hell.
  15. profdns
    Cupcake Aug 20, 2018
    profdns , Aug 20, 2018 :
    I forgot about this thread. Good work dcrnic for upkeeping.
    I have no idea why but the last couple of months, the service has been absolute shit, regardless of the ROMs, configurations, etc. done to try to rectify my signal. Of course with the US Roaming, AT&T knee-capped my data plan down to 1GB, but it's slow so it lasts forever! [Go figure].
    VoLTE works, but the data is back to pre-LTE days despite showing LTE as active.
  16. JackTheMan18
    Cupcake Aug 31, 2018
    JackTheMan18 , Aug 31, 2018 :
    Hello profdns:
    How did you get VoLTE to work?
    Does it say VOLTE at the top of your screen?
    Did you get wifi calling to work?
  17. gillau
    Eclair Oct 19, 2018
    gillau , Oct 19, 2018 :
    Rumour has it that the 6T will have band 13. Just in time given Freedom is deploying band 13 all over the place
  18. alexmb01
    Cupcake Oct 26, 2018
    alexmb01 , Oct 26, 2018 :
    Hi Everyone,
    I was wondering if anyone has been able to get on to the new 700 MHz LTE that Freedom is launching right now. I know that I might need to change my SIM but wondering if that will even make a difference because I don't see band 13 list on the device specs although there is lots of other 700 MHz frequencies.
  19. astracd
    Gingerbread Oct 27, 2018
    astracd , Oct 27, 2018 :
    if volte and wifi calling will be working on OP6T with Freedom Mobile in Canada I will get it, otherwise I'm ditching OP, and getting some other brand phone.
  20. ma678
    Eclair May 2, 2019
    ma678 , May 2, 2019 :
    Does anyone get VoLTE or WiFi calling working on OP devices?
