126
[OnePlus 5][ROM][OTA][Oxygen OS] Mirrors for official Oxygen OS ROMs and OTA updates
  1. hjs2396
    Gingerbread Jun 20, 2020
    hjs2396 , via OnePlus 5T , Jun 20, 2020 :
    go to recovery mode and just reset system settings
  2. G_vipul_handa_mNLW
    Cupcake Jun 20, 2020
  3. Shidharth Jayakannan
  4. G_vipul_handa_mNLW
    G_vipul_handa_mNLW , Jun 20, 2020 :
    Sid ..
    earlier it was showing me mobile network but once i reset my system settings . now it's is showing now signal
    Shidharth Jayakannan likes this.
  5. 82330
    Donut Jul 17, 2020
  6. Waveform Modifier
    Marshmallow Jul 17, 2020
    Waveform Modifier , Jul 17, 2020 :
    Anytime you are not upgrading, you will need to wipe all data as part of the install.
  7. 82330
    Donut Jul 17, 2020
    82330 , via OnePlus 5T , Jul 17, 2020 :
    i have to do it manually or it will automatically do that? because i don't want to wipe my data.
  8. Waveform Modifier
    Anytime you need to flash any OS outside of the OS in line with your device current upgrade path, you will need to wipe all data. For example, going from 9.0.11 to 10.0.0, you will not need to wipe. Going from 10.0.0 to anything lower or any custom OS, you will need to wipe.
    Don't want to wipe your data, than back it up. You should backup your data regardless anyways.
  9. 82330
    Donut Jul 17, 2020
    thanks for reply what if we update same version like 10 with different build.
  10. Waveform Modifier
    I think I answered that already
