76
[OnePlus 5][ROM][OTA][Oxygen OS] Mirrors for official Oxygen OS ROMs and OTA updates
  1. dhruv_paul Cupcake Nov 4, 2017
    dhruv_paul, Nov 4, 2017 :
    I'm on the leaked 8.0 closed beta but I'm facing issues with it, so I want to roll-back to a stable version. Please helpe out by guiding me how to do so.
    PS- Bootloader is LOCKED.
  2. root_rhakbari Gingerbread Nov 4, 2017
  3. dhananjay151293 Eclair Nov 5, 2017
    dhananjay151293, Nov 5, 2017 :
    Completely fine on my end. Both with 4.5.14 and leaked 4.5.2.
    Have you tried consulting the customer service center? If it is specific to your device itself, you must get it checked from them and get it repaired or replaced.
  4. dhananjay151293 Eclair Nov 5, 2017
    You can flash the full ROM zip through stock recovery.
  5. root_rhakbari Gingerbread Nov 5, 2017
    root_rhakbari, Nov 5, 2017 :
    Well there are no service centers of Oneplus in my country. I bought it from foreign but this isn't a hardware issue, this is a software or compatibility issue of SIM cards for Pakistan from Oneplus, if u go to my bug report you can get more information there.
    https://forums.oneplus.net/threads/...riod-screen-locked-mode-of-7-to-8-hrs.634492/
  6. dhananjay151293 Eclair Nov 5, 2017
  7. root_rhakbari Gingerbread Nov 5, 2017
    yes there are many in the community if u search the same issue
    dhananjay151293 likes this.
  8. Titokhan Gingerbread Nov 5, 2017
    Titokhan, Nov 5, 2017 :
    Sorry for the delay - added 4.5.14 from 4.5.x incremental OTA zips. Looks like OnePlus decided to drop making incremental OTAs for builds older than 4.5.5 and instead push full signed zip for them.
    rva likes this.
  9. Titokhan Gingerbread Nov 5, 2017
    @root_rhakbari
    You were already suggested multiple times not to repost and nag in a completely unrelated thread regarding your issues. Please stick with one thread and provide feedback through the proper channel.
  10. root_rhakbari Gingerbread Nov 5, 2017
  11. Titokhan Gingerbread Nov 5, 2017
  12. vishnuvijayk0 Eclair Nov 6, 2017
  13. Titokhan Gingerbread Nov 6, 2017
  14. vishnuvijayk0 Eclair Nov 6, 2017
  15. Titokhan Gingerbread Nov 6, 2017
    Titokhan, Nov 6, 2017 :
    Umm... then what do you wanna do next?
  16. Themurtuza Jelly Bean Nov 13, 2017
    Themurtuza, Nov 13, 2017 :
    You go on banging ur head in wall, but they won't understand, these new lot of cupcakes are all hard nuts to crack.
    We all are suffering, the more u will argue with them, more they will amaze you with their reluctance to Understand
  17. YUshaRani Eclair Nov 20, 2017
    YUshaRani, Nov 20, 2017 :
    i have installed 4.5.8 but if i check the update log there is none is this normal?
  18. covairahul Cupcake Nov 20, 2017
    covairahul, Nov 20, 2017 :
    Im currently on Oxygen OS 4.5.10,but I have recieved the OTA for 4.5.14,Is it good to do the update via OTA ? will the bugs fixed and updates from 4.5.11,12,13 be added in the OTA
  19. Titokhan Gingerbread Nov 20, 2017
    Titokhan, Nov 20, 2017 :
    @YUshaRani
    Was there any specific reason for you to install an older build? Anyway, you should get a prompt to directly update to 4.5.14 from 4.5.8, or you can grab the appropriate incremental/full OTA zip from first post and manually sideload to update.
    @covairahul
    The bug fixes are cumulative, thus the latest version contains all previous fixes. As said earlier, you can take the OTA or manually update by using the mirror OTA zips.
  20. A. Ahdach Guest Nov 21, 2017
