OnePlus 55 Q1 IN Pro stuck/freeze
  1. paritosh.bhagat
    Cupcake Jul 28, 2021
    paritosh.bhagat , Jul 28, 2021 :
    The TV is stuck while loading/booting nothing happens, even sound bar doesn't move. Tried the (1+) + (Volume Up) button recovery process. Wiped the data, did factory reset and then rebooted, waited for half an hour. Nothing is happening. I cant even update the software because it doesn't even reaches that point. Getting OnePlus service, as it is evident, is next to impossible, having waited for 15 days I have lost all my patience. Is this a faulty TV?
    PS : Any help is appreciated, also I will be uploading a video clip which might give a better picture.
  2. Venky61
    OnePlus TV Expert Community Expert Jul 30, 2021
    Best Answer
    Venky61 , Jul 30, 2021 :
    Hey, I have already escalated the issue and they said they are looking into it.
  3. B_Wrath
    Nougat Jul 28, 2021
    paritosh.bhagat and Venky61 like this.
  4. Venky61
    OnePlus TV Expert Community Expert Jul 28, 2021
    Venky61 , Jul 28, 2021 :
    Hey.. Happened after any update or randomly on a fine day when turned On the TV?
    Seems to be like there is a firware issue as it's not even working after factory reset. You can share you Reference Number of the complaint, so that I can escalate the case. Technician can help by flashing the firmware required.
    Thanks for the tag. :)
    He already mentioned that he did the factory reset by the process but no use. :rolleyes:
  5. Yash Pratap Singh.
    Lollipop Jul 28, 2021
    Yash Pratap Singh. , Jul 28, 2021 :
    What are you talking about? :p;)
    WakeAwake likes this.
  6. paritosh.bhagat
    B_Wrath likes this.
  7. paritosh.bhagat
    paritosh.bhagat , via OnePlus 7 Pro , Jul 28, 2021 :
    It happened in my absence, so the scenario which led to this is uncertain.
    I currently don't have the reference number but will get it from the customer care and post it.
    Thank you for your attention, also is this common in Q1 Pro series and what could be the most probable reason, I myself am curious.
  8. paritosh.bhagat
  9. Yash Pratap Singh.
    Have you raised a service request yet?
  10. paritosh.bhagat
    Just received the reference number of the complaint
    QXCBDFNLWNBM
  11. paritosh.bhagat
    Cupcake Jul 30, 2021
  12. paritosh.bhagat
    paritosh.bhagat , via OnePlus 7 Pro , Jul 30, 2021 :
    Could you escalate this issue, we don't have any service here, it's more than 2 weeks, some say hardware issue some say it needs to be flashed, all telephonically, nobody is attending this, my service reference is QXCBDFNLWNBM.
    Should I again raise a service request?
  13. paritosh.bhagat
    Cupcake Jul 31, 2021
  14. Trishala Anusha
    OnePlus Bug Hunter Staff Member Aug 6, 2021
    Trishala Anusha , Aug 6, 2021 :
    We are extremely sorry to hear that you are facing this issue with TV usage and thereby have sent personal message regarding the same to gather further more information.
    Regards,
    Anusha
