13
Oneplus 5T Battery drain due to Google Play services
  1. C1515986391052
    Cupcake Jan 15, 2018
    C1515986391052 , Jan 15, 2018 :
    me also think so, dont want to downgrade just wait for oreo.
    #41
  2. SUNILSAHU
    SUNILSAHU , Jan 15, 2018 :
    go to developer menu in setting, then set background process limit which you want like standard or 2 or 3 apps only. or you can choose no background app also. click also don't keep activity. i hope it might help your battery drain problem.
    trying to use gps only when it's required and always clear cheche from storage. it will boost your battery life upto certain limits. (as per my opinion) [e]1f44d[/e] Good luck mate.
    #42
  3. mandeepsingh10
    Froyo Jan 15, 2018
    mandeepsingh10 , Jan 15, 2018 :
    Thanks for your suggestions mate but the battery is performing normally in oos 4.7.4 without any tweaks so this issue is related to 4.7.6 build.
    I'll use 4.7.4 for 4-5 days and update this thread after that regarding the battery life.
    Cheers[e]270c[/e].
    #43
  4. mandeepsingh10
    Froyo Jan 15, 2018
    I wanted to do the same but in 4.7.6 my battery life was awful so I decided to revert back to 4.7.4.
    It's still good in 4.7.4 so I'll check it for 4-5 days more to be 100% sure.
    #44
  5. C1515986391052
    anything share it ,thanks mate.
    #45
    mandeepsingh10 likes this.
  6. Eric_M_Hurlbut
    Donut Jan 15, 2018
    Eric_M_Hurlbut , Jan 15, 2018 :
    I installed MacroDroid to turn off WiFi after I left my house and work. Then turn it back on when I returned.
    this saved battery life by not having the phone boosting power to the wifi to try and connect to the dozens of signals out there.
    My Moto X 1st Gen had that option built in.
    #46
  7. Zain2k
    Zain2k , Jan 15, 2018 :
    Thanks all for your input. anyone know when OREO is coming to the 5T? my other one plus 5 already got it last week.
    #47
  8. mandeepsingh10
    Froyo Jan 15, 2018
    In a month or two.
    #48
  9. K1515151836511
    K1515151836511 , Jan 15, 2018 :
    so now you downgrade your 5t from 4.7.6 to old oos 4.7.4? it's can fix battery problem? because my 5t sometimes have issue about battery life too.1% I can use 5min to 6 min but sometimes 1% can use 3min so bad feel
    #49
  10. mandeepsingh10
    Froyo Jan 15, 2018
    1% drop in 5-6 minutes is normal and sometimes the phone requires more resources so 3 minutes is also normal.
    Problem is when 1% battery is dropping consistently in 2-3 minutes otherwise you're completely fine.
    #50
    K1515151836511 likes this.
  11. K1515151836511
    oh thank
    #51
  12. Eduardo G.
    Gingerbread Jan 15, 2018
    Eduardo G. , Jan 15, 2018 :
    Try upgrading with the latest version of google services:
    https://www.apkmirror.com/apk/google-inc/google-play-services/
    Then delete the cache as I told you in another post, turn off the phone (not restart) and turn it on.
    Good luck.
    #52
  13. naught4naught
    #53
  14. mandeepsingh10
    Froyo Jan 15, 2018
    #54
  15. naught4naught
    Cupcake Jan 16, 2018
    naught4naught , Jan 16, 2018 :
    hey I just disabled permission to change settings for Google Services and I think it worked! just went a whole day with out any substantial battery drain. So far I've been off charge from 6am to 4:45pm with moderate use and I'm still at 80% (sorry if someone else already suggested this but frankly I can't be bothered to read the entire thread above haha)
    #55
  16. moskito99
    Ice Cream Sandwich Jan 16, 2018
    #56
  17. Lukegarf87
    Donut Jan 16, 2018
    Lukegarf87 , Jan 16, 2018 :
    upgrades to the Oreo Beta 2 and the Google play services battery drain issue seem to be resolved. it's only been a couple of hours.. But no issue so far. [e]1f44d[/e] good job OnePlus
    #57
  18. mandeepsingh10
    Froyo Jan 17, 2018
    mandeepsingh10 , Jan 17, 2018 :
    Which permission?
    Storage?? Because The problem disappears for some rime after clearing play services app data.
    #58
    naught4naught likes this.
  19. mandeepsingh10
    Froyo Jan 17, 2018
    I'll try it.
    #59
  20. mandeepsingh10
    Froyo Jan 17, 2018
    Even if you disable the permissions after sometime they get enable automatically.
    #60
