Oneplus 5T battery draining
  1. Gauthamdn3 Cupcake Mar 26, 2018
    Gauthamdn3, Mar 26, 2018 :
    Hello- My OnePlus 5T phone is draining. when checked , I see Android app is sucking lot of battery . the phone is forced to switch off due to this. kindly help.
    thanks
    Gautham
  2. Mohamed Allie Gingerbread Mar 26, 2018
    Mohamed Allie, Mar 26, 2018 :
    Are you on the latest version of the OS? Try clearing cache or even do a factory reset. Sometimes the device needs a cache clear which resolves most problems.
    Hydra Bob likes this.
  3. Kytharsis Lollipop Mar 26, 2018
    jmo742 likes this.
  4. 73ND41 Ice Cream Sandwich Mar 26, 2018
  5. Hydra Bob Starting Point Expert Mar 26, 2018
    Hydra Bob, Mar 26, 2018 :
    By not charging it fully so that it's taking multiple charges into account.
    OP your going to have to give us something more to go on here if you want help. A charge cycle that goes from full to nearly empty and the battery graph would be a good place to start.
    Gauthamdn3 likes this.
  6. Kytharsis Lollipop Mar 26, 2018
    Kytharsis, Mar 26, 2018 :
    That makes sense.
  7. Gauthamdn3 Cupcake Mar 26, 2018
    sure, it's charging now. I will send you the battery graph after fully charged.
    thanks so much
    gautham
  8. Gauthamdn3 Cupcake Mar 26, 2018
    battery is working fine after I charged it fully. not sure what happened before.
    thanks
  9. Gauthamdn3 Cupcake Mar 26, 2018
    I did this too.. thanks
