Oneplus 5t bluetooth won't connect to car
  1. Kadooka Cupcake Jan 7, 2018
    Kadooka, Jan 7, 2018 :
    anyone else having this issue ? Also, is there any fix to this problem?
    thanks
    navarde likes this.
  2. G_Nikos_Margaritis_KagW Gingerbread Jan 7, 2018
    G_Nikos_Margaritis_KagW, Jan 7, 2018 :
    There shouldnt be a problem. Can you connect with other phones or headphones via bluetooth? Try to troubleshoot by trying other devices first.
  3. Kadooka Cupcake Jan 7, 2018
    yeah my Nexus 6p used to work perfectly. it's a 2015 car
  4. G_Nikos_Margaritis_KagW Gingerbread Jan 7, 2018
    Try to connect oneplus 5t with other devices, maybe another phone, headphones and see if you can establish a connection.
  5. Kadooka Cupcake Jan 7, 2018
    yeah I can connect to other devices, just not for my car for some reason
  6. G_Nikos_Margaritis_KagW Gingerbread Jan 7, 2018
    Bluetooth is backwards compatible. So even if the car and your phone do not share the same version they should be able to connect. Try setting your phone bluetooth off, and click on the scanning options that appear under bluetooth panel in options. Turn bluetooth scanning on/off from there and retry. Also make sure your device is discoverable (turn on and off to make sure)
  7. Kadooka Cupcake Jan 7, 2018
    kk thanks will try that.
  8. Yams.mini Cupcake Jun 1, 2018
    Yams.mini, Jun 1, 2018 :
    My one plus 5t is not getting connected with my car Bluetooth tried several times..called to customer care but still the problem persist.
    H1527838423526 likes this.
  9. H1527838423526 Cupcake Jun 1, 2018
    H1527838423526, Jun 1, 2018 :
    Mine was working fine until a month ago but now my car menu displays no bars to make calls even though it pulls across all contacts, last rec'd calls etc from phone. my other work phone (Samsung) connects no problem as did my previous LG phone. Therefore it's not the car. I should also say that my Op5t connects normally with other Bluetooth devices such as Anker speakers.
    I have tried unpairing and repairing but to no avail. the only thing which seems to work is if I have already driven then return to the car and upon driving again the phone then connects. Very frustrating especially since I had no problems when I first got the phone.
    One Plus can you please solve this?
    G_el_djazairi likes this.
  10. rrlink Cupcake Jun 5, 2018
    rrlink, Jun 5, 2018 :
    My OnePlus 6 does the same thing with my 2018 Genesis G80. Pairs just fine - contacts there, etc. However I cannot make or receive calls through the car's Bluetooth connection. I can make and receive calls on the handset which automatically switch over to the car but that is useless while driving.
  11. zhihengl Cupcake Jun 19, 2018
    zhihengl, Jun 19, 2018 :
    my problem is: after upgrading to Oreo, the signal strength in the bluetooth icon of the car display show no bars, even though there's actually strong signals and I can make or received calls through car's bluetooth.
  12. TheFifeFlyer Froyo Jun 20, 2018
    TheFifeFlyer, Jun 20, 2018 :
    Same for me.
    Worked fine until recently.
  13. G_vinoth_kumar_ZeNv Cupcake Jun 20, 2018
  14. zhihengl Cupcake Jun 20, 2018
    zhihengl, Jun 20, 2018 :
    it's fixed in the new OS update 5.1.3.
  15. G_vinoth_kumar_ZeNv Cupcake Jun 20, 2018
    gpolydoros likes this.
  16. zhihengl Cupcake Jun 20, 2018
    it seems to have fixed my Bluetooth issue with the car so far.
  17. G_vinoth_kumar_ZeNv Cupcake Jun 20, 2018
  18. H1527838423526 Cupcake Jun 21, 2018
  19. S1521475066205 Donut Jun 21, 2018
  20. jeremyc3 Cupcake Sep 13, 2018
    jeremyc3, Sep 13, 2018 :
    My 5t is running Android 8.1 and I am having the same issue. Bluetooth used to work with my Sony XAV AX100 flawlessly, but now everything still works except for phone calls.
    Also, on side note, I am having issues with Google Map or Waze as well... GPS doesn't seem to be working when it is running of Android Auto.
