Oneplus 5t bluetooth won't connect to car
  1. mborchert Eclair Sep 13, 2018
    mborchert, Sep 13, 2018 :
    I am having the same issue. Since update to 5.1.3 my phone calls do not sync to my car deck Alpine. Music streams fine. I go to the options and there is a check box for phone but it will not allow me to select it / check it off. I have tried deleting the Bluetooth settings on the phone and car, clearing cache on Bluetooth and in recovery and nothing works. Please fix this support.
    joojoop, navarde, jkj02 and 1 other person like this.
  2. jeremyc3 Cupcake Sep 13, 2018
  3. JanneMa Cupcake Sep 13, 2018
  4. caddy_67 Cupcake Sep 13, 2018
    caddy_67, Sep 13, 2018 :
    Same problem here, phonecalls can not be selected, other services do work. But my wife that has a 5t too has no issues.....
    I tried to find differences in configuration of Bluetooth but couldn't find any.
    I hope someone finds a fix.
  5. mborchert Eclair Sep 13, 2018
    Hey guys and gals. I tried deleting cache in Settings/Apps/Application List/ All Apps/Show System Apps/ Bluetooth. Guess I needed to do it twice. All Working now .
    K1540280206921 and jeremyc3 like this.
  6. caddy_67 Cupcake Sep 14, 2018
  7. G_el_djazairi Cupcake Sep 14, 2018
    G_el_djazairi, Sep 14, 2018 :
    I have excatly the same problem.
    I have deleted my car from the phone, deleted the phone from the car, reconnect them again and nothing.
    I can listen music into the car (like JBL speaker) but calls are not going through the car.
    Once connected, I have checked also connection parameters in the OP5T and "calls" is not checked and cannot be.
  8. caddy_67 Cupcake Sep 14, 2018
  9. Rocky Rider Cupcake Sep 18, 2018
  10. Rocky Rider Cupcake Sep 18, 2018
    Rocky Rider, Sep 18, 2018 :
    same problem with my 5T
    navarde likes this.
  11. K1540280206921 Cupcake Oct 23, 2018
    K1540280206921, Oct 23, 2018 :
    Thank you. Thank you SO much, this has been driving me crazy for the last few weeks.
    Worked with OP 5T and Nokia CK-100 car kit. Was connected for Contacts / Media only, and Phone Calls would not work / could not check the option in the Bluetooth connection menu, regardless of the number of restarts, unpair / repair etc.
  12. Jasica_Nagpal Cupcake Nov 22, 2018
    Jasica_Nagpal, Nov 22, 2018 :
    My One Plus 5T cannot find my Car (hyundai Creta 2017 model) bluetooth.. It used to work fine with my Samsung Galaxy Edge device. OP5T has Android 8.1.0
