Oneplus 5T charging but not plugged in
  1. U1524990828316
    Cupcake Apr 29, 2021
    U1524990828316 , Apr 29, 2021 :
    Hi,
    Lately I have been having the issue saying that my phone is not charging. In addition, when it is not plugged, it says charging when I plug and unplug it. I have cleaned the both the charging unit and the charge socket but nothing.
  2. Caomhin
    OnePlus 9 Series Expert Community Expert Apr 30, 2021
    Caomhin , via OnePlus 9 Pro Pine Green , Apr 30, 2021 :
    FOLLOW THE STEPS BELOW TO THE LETTER CAREFULLY.
    Some say this can also help, some others state it doesn't.
    Wipe cache partition
    Turn off your device.
    Press and hold the Volume down and Power button at the same time.
    When the OnePlus logo appears, release the Power button, but continue holding the Volume down button.
    At the Password screen, enter the Password or PIN number that you use to unlock your device. When done, tap Ok.
    Tap English.
    Tap Wipe data and cache.
    Tap Wipe cache.
    Tap Yes to continue.
    Tap Reboot to restart the phone.
    Tokolozi likes this.
  3. #3
  4. ASOk191184
    Cupcake May 12, 2021
    ASOk191184 , via OnePlus 5T , May 12, 2021 :
    I'm also having same issue in 5t,. Due to frequent day to day use our charger pin got some loose connect so I cont able to sit on mobile properly does this problem occurs,,. Incase u don't move the mobile or lift the mobile on charge it I'll disconnect the charge
