2
oneplus 5t having problems
  1. JaYaNt0504
    Froyo Dec 14, 2018
    JaYaNt0504 , Dec 14, 2018 :
    I have recently observed that my phone performance is now degrading. It has been 6 months I have been using this device and now i see my Oneplus5t's performance is decreased. Swiping through apps and photes in in gallery and opening and closing of apps is not smooth now and lags a bit. Some apps like Saavn and Instagram also takes time to open and many a times it stops working and i have to reopen it. I am facing some connectivity issues too. Suddenly the cellular data stops working. I have a same carrier (Vodafone) on some other devices too which do not show such problems. There is a problem with wifi also. Many a times when i turn on my wifi it does not connect to my network, I have to turn it off and again turn it on to connect.
    I request you to please go through these problems as quickly as possible and give my solution for this. Please give updates for this device quickly since it has been a long time the update came.
    X1517396854503 and omarmawal like this.
  2. Odenholm
    Eclair Dec 14, 2018
    Odenholm , Dec 14, 2018 :
    I'd recommend that you should factory reset your phone for a fresh start. If performance is still slow check your internet speeds on your router and see if they are fast. Also the next update won't be out for another couple of weeks so you have to be patient.
  3. JaYaNt0504
    Froyo Dec 14, 2018
    i have tried all the methods you mentioned but still the problem continues. my wifi works well with other devices
  4. G_David_Sidrak_rYck
    Honeycomb Dec 14, 2018
    G_David_Sidrak_rYck , Dec 14, 2018 :
    wipe cache.
  5. Waveform Modifier
    Marshmallow Dec 14, 2018
    Waveform Modifier , Dec 14, 2018 :
    Reboot your router. Just do it. Thank me later.
  6. JaYaNt0504
    Froyo Dec 15, 2018
  7. G_David_Sidrak_rYck
    Honeycomb Dec 15, 2018
  8. redlinecoatings
    Ice Cream Sandwich Dec 15, 2018
  9. JaYaNt0504
    Froyo Dec 15, 2018
    JaYaNt0504 , Dec 15, 2018 :
    64% available
  10. B1514900966419
    Gingerbread Dec 15, 2018
