15
OnePlus 5T Karbon bumper case review
  1. handheld_addict
    Honeycomb Jan 19, 2018
    handheld_addict , Jan 19, 2018 :
    The Karbon case really isn't bulky at all, I think it's a great balance between protective and slim.
    I always go a bit crazy with case buying because I'm always looking for the perfect case for my phone. But with the 5T I was afraid there wasn't going to be many cases so I went a bit more crazy with the case buying. I've got a bunch of cases now. And this was the first phone i decided to try expensive cases like the Karbon & wood cases. In the past I've avoided $40.00 cases but this time i wanted to see if they were worth it. I still think $40.00 is a lot for a case but I'm pleasantly surprised by the fit & finish of the OnePlus Evutec cases.
    I don't think 5T owners have to spend the big bucks to get a decent case but they are definitely nice.
    #41
  2. Confednet
    Eclair Jan 20, 2018
    Confednet , Jan 20, 2018 :
    I contacted Otter Box and they say there's no plan to make a case for the 5T due to poor sales of the case for the 5.
    #42
  3. G_Nitin_Chhajed_CJuX
    Gingerbread Jan 20, 2018
    G_Nitin_Chhajed_CJuX , Jan 20, 2018 :
    ohh it's sad
    #43
  4. Natchol
    Cupcake Mar 12, 2018
    Natchol , Mar 12, 2018 :
    Just FYI everybody the phone comes with a silicone case that is totally fine and also with a protective film on the glass which is perfect. They don't make this clear at checkout and make it seem like you have to buy a case. When I wanted to return the case I bought they told me there was an admin charge of over 6euros. You really don't need to buy a case unless you want something specific.
    #44
  5. ToddskinsOrder
    Froyo Mar 12, 2018
    #45
  6. aditya2d
    Eclair Mar 14, 2018
    #46
  7. G_Ruhel_Miah_xRfn
    Eclair Mar 14, 2018
    #47
  8. mankind
    Eclair Mar 27, 2018
    mankind , Mar 27, 2018 :
    I think the inside texture are different from the outside texture (the inside are oil / smudge free than the outside). Am I right?
    #48
  9. handheld_addict
    Honeycomb Mar 27, 2018
    handheld_addict , Mar 27, 2018 :
    They have different textures, the outside is rubbery, matte, soft touch. The inside is glossy & hard feeling. It doesn't pick up oils as much but most people won't be touching the inside of the case ;)
    #49
  10. mankind
    Eclair Mar 27, 2018
    I thought so. That's the reason why I'm not buying the carbon bumper..
    #50
  11. handheld_addict
    I don't quite follow... You want the outside texture to be like the inside, or the inside to be like the outside?
    #51
  12. mankind
    Eclair Mar 27, 2018
    I want the outside texture like the inside texture.. So my oily fingerprints won't show
    #52
  13. walter820
    Eclair Apr 20, 2018
    walter820 , Apr 20, 2018 :
    I use an Oneplus tempered glass in combination with a carbon bumper case. Fits perfectly and the case does not push the glass.
    #53
    handheld_addict likes this.
  14. G_Hunter_Tran_BZPM
    Cupcake May 26, 2018
    G_Hunter_Tran_BZPM , May 26, 2018 :
    I disagree with some of the points you made. You mentioned that the camera bump gets a slight raise by the lip however it clearly is level with the lip. when you put the phone down camera side on surface the camera hits the table with a distinct glass sound. Additionally I had no issues with the edges of the case for my fingers but that's just me.
    #54
  15. handheld_addict
    Honeycomb May 26, 2018
    handheld_addict , May 26, 2018 :
    I said "very slightly above it". And I think the photos speak for themselves. But you're certainly entitled to your opinion :)
    #55
  16. L30innit
    Cupcake Aug 14, 2018
    L30innit , Aug 14, 2018 :
    #56
  17. AlMaghraby
    Cupcake Sep 4, 2018
    AlMaghraby , Sep 4, 2018 :
    this case scratches very easily and leaves light grey spots
    very annoying considering it's price
    #57
