2
Oneplus 5t otg does not work via OnePlus 5T
  1. Dpak5
    Eclair Jul 2, 2020
    Q1590823566846 and akyolsaid like this.
  2. Waveform Modifier
    Marshmallow Jul 2, 2020
    Waveform Modifier , Jul 2, 2020 :
    Mine works. Check your cable/adapter and clean your USB C port. Pretty sure this have nothing to do with the Android 10 update (Which I am on).
  3. Dpak5
    Eclair Jul 2, 2020
    Dpak5 , via OnePlus 5T , Jul 2, 2020 :
    But the adapter works perfectly fine when connected to any other android device
  4. Waveform Modifier
    So? It's not working with your 5T. So, get another one and try again. Again, mine works and had been working since Android 8. Rule of troubleshooting is replace every piece until you find out which one is at fault. Maybe it's your USB drive. Could be just your device. All I'm saying, I don't think the OS is at fault because the very fact mine works.
  5. Dpak5
    Eclair Jul 2, 2020
    I too agree android 10 has nothing to do with it. I just mentioned android 10 because in comments section ppls wil ask whic os version so. And i tried with few usb sticks it works fine in other device but not on 5t. The charging works fine but otg never gets connected
  6. akyolsaid
    Cupcake Jul 2, 2020
  7. Waveform Modifier
    I think you should still try to clean your charging port. Because OTG works in the principle that the phone provides power to the USB device instead of charging your phone. Most OTG failure is power related, therefore, you should look at why that is on your device.
  8. Dpak5
    Eclair Jul 2, 2020
    Any tips how to clean charging port?
  9. Waveform Modifier
    Get something like a needle and carefully dig around to see if anything is built up in the port.
  10. Dpak5
    Eclair Jul 2, 2020
    Wil try. Hope it dsnt damage my charging port...
  11. Bembee
    Gingerbread Jul 2, 2020
  12. Dpak5
    Eclair Jul 3, 2020
    Dpak5 , via OnePlus 5T , Jul 3, 2020 :
    Thats a very common thing iam aware of it. And i always turn it on when trying to connect otg.
  13. Dpak5
    Eclair Jul 3, 2020
    Tried it used a needle to clean the port. but still not able to connect my otg
  14. Waveform Modifier
    Marshmallow Jul 3, 2020
    Waveform Modifier , Jul 3, 2020 :
    Have you tried another OTG adapter? If so, contact OnePlus support.
