98
Oneplus 5t Oxygenos 5.0.3 PROS and CONS!!!
  1. G_Sandeep_Kumar_Tripathi
    Donut Feb 7, 2018
  2. NarendrenD
    Cupcake Feb 7, 2018
  3. ilya_lukhtanov
    Froyo Feb 7, 2018
    ilya_lukhtanov , Feb 7, 2018 :
    one more cons for Oreo update - new memo in shelf goes down, not at top as it should be logically
    Magnificent_one likes this.
  4. ValarDhoheris
    Cupcake Feb 7, 2018
  5. MLConian
    Donut Feb 7, 2018
    MLConian , Feb 7, 2018 :
    Follow the unbrick guide, then flash the last Oxygen OS version 4 build (under Legacy on the support page).
  6. kaushik_4_u
    Eclair Feb 8, 2018
    kaushik_4_u , Feb 8, 2018 :
    how to do this?
  7. G_ag_5t
    Gingerbread Feb 9, 2018
    G_ag_5t , Feb 9, 2018 :
    I already sent the link for google camera apk.Install it and select lens blur option for potrait shots,both for front and back camera
  8. G_ag_5t
    open google maps,select a destination, and start navigation and then click on the home button.You will pip mode.
    You need to update the maps app if you havent.
    G_Joseph_B_fPJl likes this.
  9. G_ag_5t
    One more Con that i am facing and missed to mention is, after taking the potrait shots using lens blur..and when we use the blur slider and adjust the blur the camera is closing automatically.If anybody is facing this issue let me know
  10. G_Biplob_Jyoti_Das_Tfim
    Donut Feb 9, 2018
  11. Syedsuhail15
    Cupcake Feb 9, 2018
    Syedsuhail15 , Feb 9, 2018 :
    Hi..!!, having a issue with face unlock post update to oreo where there is a delayed response, is it me o any 1 els facing d same issue?
  12. G_Biplob_Jyoti_Das_Tfim
    Donut Feb 10, 2018
  13. G_Joseph_B_fPJl
    Donut Feb 17, 2018
    G_Joseph_B_fPJl , Feb 17, 2018 :
    I believe it's quite simple. Hit the little red "message" icon at the bottom of a Thread you want to comment on. Once you do so, you'll be presented w a blank "page" to start typing your comment. At the bottom left where, there should be a "gallery" looking icon. Click that and anything photos or screen shots you took and saved to your phone's gallery, should be available to submit on your comment. I sure hope I'm not incorrect and I hope this helps. [e]1f609[/e]
  14. G_Joseph_B_fPJl
    Donut Feb 17, 2018
    Did you get @G_ag_5t reply to your question?
