98
Oneplus 5t Oxygenos 5.0.3 PROS and CONS!!!
  1. siddharthnarang
    Donut Feb 4, 2018
    #41
  2. G_ag_5t
    Gingerbread Feb 4, 2018
    #42
    sarathsnairxyz likes this.
  3. Nicholas7898
    Donut Feb 4, 2018
    Nicholas7898 , Feb 4, 2018 :
    When I double tap on a notification when the screen is locked with fingerprint, it doesn't unlock and open the notification, but the screen become darker (look fhe screenshot) and I have to turn off the screen. Has anyone has this issue? This problem wasn't present with the 4.7.6 1517766445333.jpg
    #43
  4. G_Costin_O_oHpX
    G_Costin_O_oHpX , Feb 4, 2018 :
    Battery is improved indeed, but how do you get the pip to work by example look into youtube and browse on chrome?
    #44
  5. Y1516037334184
    Donut Feb 4, 2018
    #45
  6. motanes
    Donut Feb 4, 2018
    motanes , Feb 4, 2018 :
    I installed Oreo with VPN from Canada. I recommend using the Google Play app called TURBO VPN. It's good to be on WIFI and have the battery over 80%.
    #46
  7. Y1516037334184
    Donut Feb 4, 2018
    #47
  8. motanes
    Donut Feb 4, 2018
    I still have 5.0.2 How did you install 5.0.3?
    #48
  9. W1515852396156
    Cupcake Feb 4, 2018
    W1515852396156 , Feb 4, 2018 :
    having issues in one plus camera app, once in a day it will get hang and I have to restart my phone and den it will work .
    how to solve this issue
    #49
  10. Andeeh
    Cupcake Feb 4, 2018
    Andeeh , Feb 4, 2018 :
    will this come to the oneplus 3 ? and 3T ??? I can't afford the 5T [e]1f623[/e][e]1f623[/e][e]1f623[/e][e]1f623[/e]
    #50
  11. W1515852396156
    Cupcake Feb 4, 2018
    #51
  12. G_ag_5t
    G_ag_5t , Feb 4, 2018 :
    You need to open chrome and in the settings, select request desktop site check box,Then open youtube through crome,tap on wide screen and then tap on home button..you will get pip function
    #52
  13. G_ag_5t
    go to settings,open application lists, selct camera app,clear camera cache and restart camera.Hope that solves the issue
    #53
  14. Mahammad94
    Ice Cream Sandwich Feb 4, 2018
    #54
  15. callmesleeper
    Froyo Feb 4, 2018
    callmesleeper , Feb 4, 2018 :
    Starting with Cons/worsening:
    1.
    I experience that the camera is worse on 5.0.3. (to clarify, this is the version I got at the same time as Oreo installed)
    Its like a ghosting effect on everything not centered in the shot. Like motion blur but like I'm zooming in to get the effect. (even on tripod)
    This effect wasn't there before.
    It's frustrating that Oneplus is basically shitting on the camera software. It's proven that it's the software at fault for the majority of the issues.
    2.
    Other than that I get "misses" in vibration/haptic feedback when typing. (using SwiftKey)
    This makes me feel like my tap on a letter didn't register.
    But it did, it was just the vibration that didn't trigger.
    This happens about every 3-4 letters. (I'm typing quite fast)
    This was not an issue at all before.
    Some Pros/improvements:
    1.
    Ironically, the touch is much better. (near the edges)
    Before I could tap the back-button 3-4 times before it registered.
    And to pull down the notifications I had to do it very slowly before or it wouldn't work.
    Now these things rarely misfires. [e]1f44d[/e]
    2.
    The finger print sensor seems to work better as well for pulling down/up the notifications. Responds quicker.
    3.
    Double tap on power button works far better now too.
    The camera opens every time now, and the vibration is shorter. [e]1f44d[/e]
    #55
  16. satishtmsk
    Donut Feb 4, 2018
    satishtmsk , Feb 4, 2018 :
    it's works. pl try once again...i got that, but just thinking whether go for oreo update using vpn or not
    #56
  17. naman38
    Donut Feb 4, 2018
    #57
  18. satishtmsk
    Donut Feb 4, 2018
    using opera VPN (Germany), u get ota update 5.0.3...
    #58
    Andyobl and naman38 like this.
  19. N1517217614602
    Cupcake Feb 4, 2018
    #59
  20. naman38
    Donut Feb 4, 2018
    naman38 , Feb 4, 2018 :
    got it thanks broda...
    #60
    satishtmsk likes this.
