98
Oneplus 5t Oxygenos 5.0.3 PROS and CONS!!!
  1. gregsrush
    Cupcake Feb 4, 2018
    gregsrush , Feb 4, 2018 :
    Because mine is not working on Oxygen 5.0.3, any advice?
    #81
  2. G_Biplob_Jyoti_Das_Tfim
    Donut Feb 4, 2018
    #82
  3. kumaryashwin
    Jelly Bean Feb 4, 2018
    #83
  4. G_ag_5t
    Gingerbread Feb 5, 2018
    G_ag_5t , Feb 5, 2018 :
    Go to settings and type picture in picture.You will see all the apps that support that feature.To see youtube videos in pip.Go to chrome,settings,request desktop site and then go you youtube through chrome and select any video,tap on full screen mode and tap on home button.You will get pip.
    #84
  5. sarathsnairxyz
    Eclair Feb 5, 2018
    sarathsnairxyz , Feb 5, 2018 :
    I followed your instructions. Downloaded the update using vpn then cleared cache from settings and recovery. after that the update is not showing in the system updates section. Is it deleted?
    #85
    calvincjh likes this.
  6. G_ag_5t
    after recovery reboot you should again use the vpn app.Then only the update will showup.Close the vpn only after installing the update
    #86
    sarathsnairxyz likes this.
  7. Q1514571827060
    Donut Feb 5, 2018
    Q1514571827060 , Feb 5, 2018 :
    it took so long when dubble press power button to lunching camera while phone is lock ( black screen )
    anyone get same problem?
    #87
  8. rahulberuwar11
    Donut Feb 5, 2018
    rahulberuwar11 , Feb 5, 2018 :
    my battery life has reduced drastically.. can anyone help after Oreo update m not able to completely clear my cache memory. even after clearing. it always shows cache memory 8 MB.. have also tried the recovery mode cache clearing.. and storage memory clearing... please help
    #88
    cdxpmop likes this.
  9. G_ag_5t
    Follow the steps which i mentioned in order.And close all apps frm background when not using.
    #89
  10. sathyaravi31
    Eclair Feb 5, 2018
    sathyaravi31 , Feb 5, 2018 :
    restart your mobile
    #90
  11. cdxpmop
    cdxpmop , Feb 5, 2018 :
    you should report this as a bug to OnePlus. I had the same issue when I tried the beta. I updated to 5.0.3 and the same cache issue was still there. so I rolled back to nougat. I tried wipe cache and that didn't help. I had reported to OnePlus. but they didn't fix it. I suspect a lot more people would have the cache issue. but ppl probably haven't paid attention to that.
    #91
  12. arekstefanek
    Eclair Feb 5, 2018
    arekstefanek , Feb 5, 2018 :
    The same thing here, this is the issue several people have.
    #92
  13. vivekgokulraj
    Honeycomb Feb 5, 2018
    vivekgokulraj , Feb 5, 2018 :
    normally for a stable update there is no need to do any cache clearing or wiping.. after installing if any bug appears u can clear them. I didn't clear or wipe cache memory but it's still works fine
    #93
  14. rahulberuwar11
    Donut Feb 5, 2018
    how can we move back to nougat
    #94
  15. sathyaravi31
    Eclair Feb 5, 2018
    #95
  16. rahulberuwar11
    Donut Feb 5, 2018
    #96
  17. sathyaravi31
    Eclair Feb 5, 2018
    #97
  18. cdxpmop
    #98
    Infinityplayer1 likes this.
  19. sathyaravi31
    Eclair Feb 5, 2018
    #99
  20. cdxpmop
    this is the same process. don't ask why I know
