98
Oneplus 5t Oxygenos 5.0.3 PROS and CONS!!!
  1. aakashsood
    Jelly Bean Feb 5, 2018
    aakashsood , Feb 5, 2018 :
    Hey. Thanks for the link. But it is normal Google camera not the ported one. Can you extract the apk of the gcam that you are using, upload it on drive and post the link here please?
    h_kashyap likes this.
  2. AqeebMohammed
    Honeycomb Feb 5, 2018
    AqeebMohammed , Feb 5, 2018 :
    Can any one explain me 5th point, thanks for the review.
  3. AqeebMohammed
  4. vivekgokulraj
    vivekgokulraj , Feb 5, 2018 :
    what he meant is one can easily switch the data connection between sim cards using new toggle.
    AqeebMohammed likes this.
  5. AqeebMohammed
    Thanks, but how? settings?
  6. vivekgokulraj
  7. NAVABAHMAD
    Cupcake Feb 5, 2018
    NAVABAHMAD , Feb 5, 2018 :
    hi, I am still using oxygenos 4.7.. can anybody tell me how to update into 5.0.3
  8. G_ag_5t
    Gingerbread Feb 5, 2018
    G_ag_5t , Feb 5, 2018 :
    Bro that is the google pixel 2 camera.You have hdr +,front and back cam potrait mode features etc.That is the one everyone is using.
  9. aakashsood
    It has lens blur feature which is not equal to the portrait mode on pixel 2.
  10. rahulberuwar11
    Donut Feb 5, 2018
    rahulberuwar11 , Feb 5, 2018 :
    please help how to do that.. i.e. official recovery.. my battery is draining very fast..
  11. G_ag_5t
    Lens blur is the same feature used in pixel 2. You can google it.That same feature can be used by us now through this apk.It takes selfie potrait shots as good as the pixel 2
  12. Saranm6
    Saranm6 , Feb 5, 2018 :
    I would like to add some more cons
    1. clear all option not available anymore for notifications.
    2.they should have given us option to turn on vibration feedback for fingerprint unlock.
    3.some apps are crashing don't know if it is problem on apps side or OnePlus side will wait till I get updates on apps.
  13. Saranm6
  14. G_Biplob_Jyoti_Das_Tfim
    Donut Feb 5, 2018
  15. G_Jessie_Tomich_izOb
    G_Jessie_Tomich_izOb , Feb 5, 2018 :
    I just used the oxygen updater on the Google app store.
    NAVABAHMAD likes this.
  16. G_Jessie_Tomich_izOb
    I honestly can't tell much difference. The battery life seems to be much better but other than that it looks and acts about the same. Sure there are some small differences but I really don't get why people were so awaiting it.
    calvincjh likes this.
  17. Varinder.pes
    Eclair Feb 5, 2018
    Varinder.pes , Feb 5, 2018 :
    i hv updated my op5t using vpn canada but one problem is how to change internet from one sim to other. before update it was very easy.
  18. aakashsood
    G_ag_5t
    Lens blur is the same feature used in pixel 2. You can google it.That same feature can be used by us now through this apk.It takes selfie potrait shots as good as the pixel 2​
    Wrong bro! Lens blur has been there previously as well. There's a separate mode on pixel 2 now. See the attached screenshots
    G_Nihar_Jain_ likes this.
  19. G_ag_5t
    That is exclusive to the pixel 2 phone.Non pixel phones have lens blur instead of potrait.Both perform the same function.
  20. sal82
    sal82 , Feb 5, 2018 :
    what white circle? screenshot please.
