98
Oneplus 5t Oxygenos 5.0.3 PROS and CONS!!!
  1. MLConian
    Donut Feb 5, 2018
    MLConian , Feb 5, 2018 :
    Pros:
    Great battery life.
    Really responsive.
    Quick data SIM toggle.
    Cons:
    After the update, the phone regularly doesn't unlock with the fingerprint scanner - instead of unlocking, the phone just greys out my lockscreen.
    Notifications no longer function properly - WhatsApp and text messages are constantly reset to 'urgent'.
    As was mentioned under 'Pros' by the topic starter, fingerprint unlock no longer makes the phone vibrate. I liked the tactile feedback of the fingerprint sensor, so I consider it a con.
    Also, Parallel Spaces is not responding under Oreo on the 5T, so the WhatsApp for my second SIM is no longer functioning. I am aware that this is a problem with the app, not OnePlus.
    Verdict:
    I'm downgrading to Android 7 again, the phone is not usable for me in a business setting at the moment. Once all the issues are addressed I'll update again, because the added speed and battery life are very welcome - but not at the cost of stability and usability.
  2. A1514399754491
    Cupcake Feb 5, 2018
    A1514399754491 , Feb 5, 2018 :
    can you please guide us how to downgrade
  3. Vinicius_Castro
    Gingerbread Feb 5, 2018
    Vinicius_Castro , Feb 5, 2018 :
    Oh, OK thanks. I'm from Brazil and I've didn't notice this mkey app on 5.0.2 version neither on 5.0.3 version. Anyway, OnePlus should advice us.
  4. hemanthjasti
    Cupcake Feb 5, 2018
    hemanthjasti , Feb 5, 2018 :
    The only issue I've got so far is I miss the old hide navigation bar with smart dot. I personally prefer that navigation bar over gestures. I wish they bring it back as a third option. Also keep the onscreen Navigation bar transparent instead of white.
    calvincjh and kunalmalhotra11 like this.
  5. kunalmalhotra11
    Donut Feb 5, 2018
    kunalmalhotra11 , Feb 5, 2018 :
    I'm no expert but had the same issue, I tried connect to many countries such as Germany and Canada via Opera VPN. However, I was unsuccessful. I ended up using a VPN called "Turbo VPN", connected it to Canada and received the update in a matter of a few seconds!
    Link:
    https://play.google.com/store/apps/details?id=free.vpn.unblock.proxy.turbovpn
  6. 12457474856
    Cupcake Feb 5, 2018
  7. Varinder.pes
    Eclair Feb 5, 2018
    Varinder.pes , Feb 5, 2018 :
    I got screen on time of 8 hours today on OnePlus 5T Android Oreo. Amazing battery after update.
    kunalmalhotra11 likes this.
  8. kunalmalhotra11
    Donut Feb 5, 2018
    Q1513235136151 likes this.
  9. 12457474856
    Cupcake Feb 5, 2018
  10. kunalmalhotra11
    Donut Feb 5, 2018
  11. billdakoutros
    Eclair Feb 5, 2018
    billdakoutros , Feb 5, 2018 :
    i did a hard reset and for 2days the ring tone works fine.try it
  12. Vinicius_Castro
  13. girishgondi
    Cupcake Feb 5, 2018
  14. gouskini
    Cupcake Feb 5, 2018
  15. rafaykhalid89
    Cupcake Feb 5, 2018
    rafaykhalid89 , Feb 5, 2018 :
    Updated on Oreo (5.0.3) a couple of days ago.. The update is quite stable though with excellent battery life. There's just one issue I have yet to discuss and it's becoming a little annoying. I have enabled app locker for most apps including WhatsApp and whenever I open a new message straight from the lock screen the WhatsApp security screen takes a good 5-10 seconds to load. It was instant previously.
    No issues if I turn the app locker off, WhatsApp opens instantly. The issue only occurs when the app is locked.
  16. rafaykhalid89
    Cupcake Feb 5, 2018
    Yes.. Exactly same issue with me, it's getting annoying..
    The only workaround is to unlock the screen and then click on the notification..
  17. arekstefanek
    Eclair Feb 5, 2018
    arekstefanek , Feb 5, 2018 :
    The second method is just wait few seconds and the screen will change to the second security screen to enter the app [e]1f609[/e].
    But like you said, it is VERY annoying, especially in the previous version everything works fine.
  18. rafaykhalid89
    Cupcake Feb 5, 2018
    And the final one is to remove the app from app locker. Can get a bit dangerous though if you've enabled face unlock. My friends usually pick up my phone when I'm driving, bring it in front of my face and BAM it's unlocked [e]1f602[/e]
  19. arekstefanek
    Eclair Feb 5, 2018
    Well, for the few reasons I'm forced to use the app lock [e]1f609[/e]. That's why I'm very piss off that the one of the most important feature don't work correctly...
  20. Tomas Novansky
    Cupcake Feb 5, 2018
    Tomas Novansky , Feb 5, 2018 :
    I got same issue...OperaVPN, Turbo and also oxygen updater doesn't work.Tried change region Canada and Germany, btw. live in Netherlends, but still nothing...who can help me?!
