ONEPLUS 5T TO MAC
  1. menachemdahan
    Cupcake Apr 12, 2018
  2. Jawe1212
    Eclair Apr 12, 2018
  3. maurinator
  4. B1523499528410
    B1523499528410 , Apr 12, 2018 :
    Sometimes I use ' Handshaker', made from Smartisan, feeling like using airdrop in iOS, but still can use your charge cable.
  5. menachemdahan
  6. menachemdahan
    menachemdahan , Apr 12, 2018 :
    I use it to but in am apt with guys and not really good wifi connection so doesnt really help me
  7. maurinator
    maurinator , Apr 12, 2018 :
    is your lockscreen unlocked - like past the pin screen ? one thing I've noticed is that if I connect my phone when it's locked it does not show my phone's content (probably bc of security issues )
  8. menachemdahan
    me 2 but takes too long to download 5 min clips on my comp
  9. menachemdahan
    yes I plug when unlocked
  10. aakashsood
    Jelly Bean Apr 12, 2018
    aakashsood , Apr 12, 2018 :
    And you have to choose file transfer too from the phone. Hope you are doing that. I use my phone with Mac all the time and it works flawlessly.
    maurinator likes this.
  11. menachemdahan
    how to I choose that
  12. aakashsood
    When you connect your phone to the mac, drag down the notification tray on your phone. You'll see something like USB charging this device. Click on it and click on transfer files.
    Alternatively, you can also click on transfer photos if you just want to transfer photos but I haven't used that option personally.
  13. menachemdahan
    I know what you're talking about but like I don't know ow if there's something wrong with my phone or my computer or both but I don't see it in notification tray
  14. aakashsood
    Then maybe try a different a different cable because sometimes cables are faulty although they charge just alright.
  15. Abraham_W08
    Eclair Apr 12, 2018
    Abraham_W08 , Apr 12, 2018 :
    Mine used to be like that, didn't showed any notification. So I went to Settings and put Android System notifications in priority, at the top of all notifications. And finally showed the damn notification. Try it and see.
  16. menachemdahan
    it's the OnePlus cable
  17. aakashsood
    It's not indestructible as far as I know.
