OnePlus 5T
  1. G1527673663432 Donut Jun 26, 2019
  2. G1527673663432 Donut Jun 26, 2019
    G1527673663432, Jun 26, 2019 :
    but I'm changing color led light
  3. B_Wrath Marshmallow Jun 26, 2019
  4. Waveform Modifier Marshmallow Jun 26, 2019
  5. John Wagner Eclair Jun 26, 2019
    John Wagner, Jun 26, 2019 :
    For those that are facing charging problems. I suggest you to goto your Dailer and enter this code: *#808# which is a Official OnePlus manufacturers test code. Once you have entered it now you're in the factory test menu so swipe over to Device Debugging then
    scroll down where you see "Charger(Fastcharging)" tap on it and connect your cable to see what's the actual amperage.
    If your device is below 50% you should be charging near 2900-3350mah with a Dash charging cable and if its below 2A charging mark well the cable maybe damaged/Defective or Not a OEM Product even too the usb type c port on your device is dirty from dust, lint etc or damaged from general usage or even from forcing etc.
    I suggest check with another cable too and use your OEM charger that came with your device.
    Drasm19 likes this.
  6. artloverjv Ice Cream Sandwich Jun 27, 2019
    artloverjv, Jun 27, 2019 :
    Your fast charge go bad. Service center, going for help.
    0-100% how much time?
  7. artloverjv Ice Cream Sandwich Jun 27, 2019
    buntycubal likes this.
  8. borft Jelly Bean Jun 27, 2019
    borft, Jun 27, 2019 :
    what's up, ran out of verbs?
    John Wagner and artloverjv like this.
  9. Joehad83 Honeycomb Jun 28, 2019
  10. pablofg1978 Spanish POC Assistant Head Moderator Jun 28, 2019
    pablofg1978, Jun 28, 2019 :
    I think that he means the human between the phone and the wall socket....
  11. John Wagner Eclair Jun 28, 2019
  12. Waveform Modifier Marshmallow Jun 28, 2019
    Waveform Modifier, Jun 28, 2019 :
    You must admit, it could be interpreted both ways...
  13. Joehad83 Honeycomb Jun 29, 2019
    Joehad83, Jun 29, 2019 :
    Exactly! It is a joke. This thread is hilarious!
  14. Akhshay Srinivasan Nougat Jun 29, 2019
  15. D1561804747039 Cupcake Jun 29, 2019
    D1561804747039, Jun 29, 2019 :
    Ciao a tutti,non ho mai utilizzato il forum per scrivere,dato che non ho mai avuto necessità, perché non avevo mai problemi con il dispositivo, però é più di qualche settimana che riscontro un problema molto grave,nel dispositivo ho 2 SIM,una Vodafone una Tim,il problema principale lo riscontro con Vodafone,che poi è la mia sim principale,e se anche ho una buona ricezione,se mi contattano non mi arrivano chiamate è come se non fossi raggiungibile ,se effettuo una telefonata non riesco a farla,e per chiamare e ricevere devo spesso uscite fuori casa,questo problema si sta verificando in questo periodo,prima non avevo problemi. Non sò se qualcuno può aiutarmi a riguardo.
    Hi everyone, I have never used the forum to write, since I never had need, because I never had problems with the device, but it is more than a few weeks that I find a very serious problem, in the device I have 2 SIM, one Vodafone a Tim, the main problem is the response with Vodafone, which is my main sim, and even if I have a good reception, if they contact me I don't get calls it's like I'm not reachable, if I make a phone call I can't do it , and to call and receive I often have to go out, this problem is occurring in this period, before I had no problems. I don't know if anyone can help me.
