OnePlus 6 & 6t pocket mode fix via OnePlus 6T
  1. Ganasiva
    Eclair May 6, 2021
    Ganasiva , via OnePlus 6T , May 6, 2021 :
    Dear OnePlus team,
    Myself and my brother using Oneplus 6 & 6t devices.
    We didn't experience these kind of problem
    I thought it might be an hardware problem
    We both are experiencing this pocket mode issue after we updated the oxygen OS version to 10.3.9
    Please fix this issue as soon as possible
    Thank you
  2. Bobbie63
    Marshmallow May 6, 2021
    Best Answer
    Bobbie63 , May 6, 2021 :
    What if you reboot?
    What if you turn off the pocket mode , reboot and turn it on again?
    Have you recently applied a new screen protector that could be blocking the sensor?
  3. harshit.b.
    Ice Cream Sandwich May 6, 2021
  4. sumitMZ007
    Jelly Bean May 6, 2021
  5. Arjun_Choudhry
    KitKat May 6, 2021
    Arjun_Choudhry , May 6, 2021 :
    Do you use a tempered glass? Does it have cutouts for the earpiece and the front camera? If yes, time to put a new tempered glass, as the old one has accumulated a lot of dust (which can't be removed easily)
  6. Ganasiva
    Eclair May 6, 2021
    Brother, a month before I had changed the whole display set of my OnePlus 6t, its new one. A screen guard already applied in it, I didn't change it.
    It's clean and clear. No dust
  7. Ganasiva
    Eclair May 6, 2021
    I'll give a try and share if my problem solved brother
    Bobbie63 likes this.
  8. Ganasiva
    Eclair May 6, 2021
  9. Ganasiva
    Eclair May 6, 2021
    I'll try it brother
    Bobbie63 and sumitMZ007 like this.
  10. Arjun_Choudhry
    KitKat May 6, 2021
    Change the screen guard. I had the same issue on my OP6, which got solved on taking off the tempered glass (dust or the screen protector may be covering the proximity sensor)
    Shailender Sharma and Bobbie63 like this.
  11. Ganasiva
    Eclair May 7, 2021
    Ganasiva , via OnePlus 6T , May 7, 2021 :
    Thanks brother.
    I had followed your steps
    Till now I didn't face pocket mode problem
    Thanks for the solution
  12. Ganasiva
    Eclair May 7, 2021
    Now im getting the same issue
    Problem not solved
  13. Bobbie63
    Marshmallow May 7, 2021
    Bobbie63 , May 7, 2021 :
    Weird, it still could be the screen protector you applied, however you could follow the same steps again and additionally clear the cache of the OnePlus launcher, I’m not sure though if then pocket mode is part of the pocket mode. This however will clear you homescreen setup and you’ll need to set it up again.
    if that all doesn’t work, best is to give feedback here.
  14. Arjun_Choudhry
    KitKat May 7, 2021
    Arjun_Choudhry , May 7, 2021 :
    It is definitely the screen protector. Had the same issue a couple of months back on both my OP6s (different time periods). Removed the tempered glass, and the issue got rectified
  15. Bobbie63
    I'd say the same, seen this a lot also with the 8 series I think, it's sensoring the side of the glass or so, not sure.
  16. Shailender Sharma
    Shailender Sharma , May 7, 2021 :
    And I have ordered a official tempered glass for my device. Might be going to face the same issue? :rolleyes:
    Arjun_Choudhry likes this.
  17. Bobbie63
    Stick it on the right way, although I have seen the issue with Nord also quite a lot, come to think of it.
  18. Arjun_Choudhry
    KitKat May 7, 2021
    Don't think so. As long as you align it perfectly (and regular cleaning with a micro-fiber cloth to remove the dust goes a long way)
    Bobbie63 and Shailender Sharma like this.
  19. Shailender Sharma
    Thanks, will do the same :)
    Bobbie63 and Arjun_Choudhry like this.
