Oneplus 6 automatic Rebooting problem. via OnePlus 6
  1. Q1627673880181
    Cupcake Jul 30, 2021
    Q1627673880181 , via OnePlus 6 , Jul 30, 2021 :
    I have a Red Oneplus 6 with 8 gb Ram and 128 Gb storage.
    Few days ago my Oneplus automatically started rebooting every 5-7 minutes untill the battery was dead.
    After that after sometime it was back again looking in good condition but again after sometime it goes into the same rebooting problem and this loop is going on.
    I noticed some problems after rebooting started:
    1. Wi-Fi doesn't switch on when I try to switch it on it automatically turnd itself off.
    2. No sim card Is detected even after replacing new sim in sim slot.
    3. Oneplus hangs automatically and then restarts itself.
    I tried resetting the phone to factory defaults also cleared cached but nothing worked.
    Please someone tell me the solution of this 🙏
  2. Artemus.
    Community Hero 2020 Jul 30, 2021
    Artemus. , Jul 30, 2021 :
    What OOS version are you on?
  3. Q1627673880181
    Currently I am on OOS 9
    Was on android 10 but now after the issue I downgraded it to Android 9 to see if the problem is gone but it doesn't had any effect on the problem. The problem still continues after downgrading the OS from android 10 to 9
  4. Q1627673880181
    Cupcake Jul 31, 2021
  5. mojoyoyo77
    Assistant Head Moderator Assistant Head Moderator Jul 31, 2021
    mojoyoyo77 , Jul 31, 2021 :
    Moved thread to OnePlus 6 General Support
  6. Q1627673880181
  7. Q1627673880181
    Cupcake Aug 4, 2021
  8. K1576878183954
    Cupcake Aug 17, 2021
