OnePlus 6 battery heat up after new update via OnePlus 8 Pro
  1. NG2310
    Cupcake Oct 24, 2021
  2. Dresa91
    User of the Year 2016; Most Active User 2020 Community Expert Oct 24, 2021
    Dresa91 , Oct 24, 2021 :
    In which situations?
    Did you perform a factory reset after the major update, which is always recommended when one is facing issues?
  3. NG2310
    NG2310 , via OnePlus 8 Pro , Oct 24, 2021 :
    Whenever using any app (Facebook, instagram). And why would I do a factory reset after update, makes no sense to me for a basic everyday user.
  4. Dresa91
    As I said: major update and when one is facing issues,..
    I always did a factory reset after a major update (for example A10 - A11).
    Doesn’t matter if it was a Sony, Samsung, Google or OnePlus device.
    I never faced issues .
    Just a recommendation.
    Sometimes you build up bugs and issues in a usage cycle. And with a new update you also update those built up bugs and issues. And then a factory reset after a major update can help
    drl431 likes this.
