2
OnePlus 6 battery life
  1. Vrushab kumar Cupcake Jan 9, 2019
    Vrushab kumar, Jan 9, 2019 :
    The battery is draining out too quickly..is their a problem with my phone or is it something to do with the software
  2. Raresch Honeycomb Jan 9, 2019
    Raresch, Jan 9, 2019 :
    you have provided minimum info about your problem. this is not enough for anyone to give you a good answer. please put a screenshot with you battery usage, to see which app is draining so quickly.
    p.s. if you just updated, let your phone go through 2-3 charging cycles to stabilise itself
    Sargo likes this.
  3. jasonnaz007 Cupcake Jan 9, 2019
    jasonnaz007, Jan 9, 2019 :
    This is true. The battery is draining quite quickly after the 9.0.3 update .Please fix this issue
  4. anilraj143j Eclair Jan 9, 2019
    anilraj143j, Jan 9, 2019 :
    how much you are expecting.... depends upon usage of it...mine 9.0.3 gets good battery life...
  5. jasonnaz007 Cupcake Jan 9, 2019
  6. anilraj143j Eclair Jan 9, 2019
    give time to settle the updtae...it's take some time..after wards you will get good battery life....
    Raresch and jasonnaz007 like this.
  7. anilraj143j Eclair Jan 9, 2019
  8. jasonnaz007 Cupcake Jan 9, 2019
  9. anilraj143j Eclair Jan 9, 2019
    s...but I usually charge till 90%...
  10. jasonnaz007 Cupcake Jan 9, 2019
  11. anilraj143j Eclair Jan 9, 2019
  12. Roger.T Honeycomb Jan 9, 2019
    Roger.T, Jan 9, 2019 :
    You have to go for a day or two and load a few times until the system adjusting..
    A fresh update and then scold again about the battery is unnecessary..
  13. jasonnaz007 Cupcake Jan 9, 2019
    I guess it's been two weeks since I have updated to 9.0.3 and I noticed the battery issue few days back.
  14. L1547049801594 Cupcake Jan 9, 2019
    L1547049801594, Jan 9, 2019 :
    Right on the question, can you completely wipe the OP
    Launcher from your device?
    The reason - a massive battery drain caused by it
    Before my last charge, the launcher had consumed 27% of
    he battery. Usually is around 10-15%
    No widgets on the home screen, the only gesture which I'm
    using is double tap to wake/lock.
    A few days ago I contacted the OP support. The guy there
    told me to delete the launcher and that the phone cah work
    as good as ever even without it
    I asked if the launcher would be completely wiped or just
    replaced with an old version and he assured me that it'll be
    gone for good. (have a screenshot with the conversation)
    Can anyone give an advise on what may cause the launcher to be so battery inefficient, and if it's possible for the phone to work without the launcher?
  15. JAGADISH BHATTA Ice Cream Sandwich Jan 10, 2019
    JAGADISH BHATTA, Jan 10, 2019 :
    What:eek:,battery life is improved in 9.0.3 update.I am getting better battery life now and please post a screenshot of your battery graph and Battery stat page.
  16. m.n.o_17 Cupcake Jan 12, 2019
    m.n.o_17, Jan 12, 2019 :
    I agree, I got my phone on the 28th of December, updated on the fifth and since then my phone drains a lot faster. The battery is still good and I don't dash charge much so it's either the update or the apps I have
  17. G1547531895213 Cupcake Jan 15, 2019 at 6:02 AM
