Oneplus 6 Bluetooth devive with Spotify issue
  1. Nashzotic Cupcake Jun 16, 2018
    Nashzotic, Jun 16, 2018 :
    I'm having the same problem with my OP6.. initially I thought was my Bluetooth device that I connected was the problem. But I soon realise both my Honda and Toyota car's Bluetooth also having this problem.
    The song will randomly pauses for a few millisecond and play and pauses and play and pauses and play very often and randomly. it is really annoying. And even unlocking the phone also pauses the songs a few millisecond..I don't have this issue with 2 of my previous phones...
    any solution guys??
  2. allen722 Cupcake Jun 16, 2018
    allen722, Jun 16, 2018 :
    I had the same problem.
    what I did is the following:
    go to devolper setting, go down to Bluetooth and change the Bluetooth AVRCP to 1.6.
    I hope this works for you too.
    cheers
  3. Nashzotic Cupcake Jun 16, 2018
    ohh, sorry I'm quite bad with tech. how do you go to developer mode?
  4. allen722 Cupcake Jun 16, 2018
    How to enable Developer options in Android
    If using stock Android, go to Settings > About phone > Build number. On a Samsung Galaxy device, go to Settings > About device > Build number. ...
    Tap Build number seven times. ...
    Go back to Settings, where you'll find a Developer options entry in the menu.
  5. Nashzotic Cupcake Jun 16, 2018
    ok cool, gonna try it out. thanks man!
  6. Aditya goyal Donut Jun 16, 2018
    Nashzotic likes this.
  7. Nashzotic Cupcake Jun 16, 2018
    sadly, I have tried changing it to 1.6 but still no luck..
    I noticed alot of ppl having the same problem since previous models.. I really hope the Devs are doing something abt it.
  8. V1P_J0K3R Honeycomb Jun 17, 2018
    V1P_J0K3R, Jun 17, 2018 :
    have the same issue.
    change in the bluetooth Settings that the Device only can Music Streaming (no contacts or Telephone)
    works for me fine now but thats only a workaround not a problem solver
  9. Aditya goyal Donut Jun 23, 2018
    Aditya goyal, Jun 23, 2018 :
    Found the solution for this. Just change the bluetooth setting in developer option like given below
  10. V1P_J0K3R Honeycomb Jun 23, 2018
    V1P_J0K3R, Jun 23, 2018 :
    have this Settings already but it doesn't work with my Anker Soundcore Sport XL
  11. Nashzotic Cupcake Jun 24, 2018
    Nashzotic, Jun 24, 2018 :
    doesn't work. this setting is the original settings.
  12. Aditya goyal Donut Jun 24, 2018
    Aditya goyal, Jun 24, 2018 :
    Try changing the avrcp version to 1.6. Hope it works
  13. Nashzotic Cupcake Jun 24, 2018
    tried that too, didn't work. Allen 1st suggested that, but no luck.
  14. Aditya goyal Donut Jun 24, 2018
    I think now the last option left is factory reset
  15. Aditya goyal Donut Jun 24, 2018
    Now the last solution is factory reset :(
  16. Nashzotic Cupcake Jun 24, 2018
    I don't think is factory reset will work. most ppl are having this problem since previous models.
  17. Aleksander_Mortensen Cupcake Jun 24, 2018
  18. Arthur.orin Honeycomb Jun 24, 2018
  19. Nashzotic Cupcake Jun 24, 2018
  20. Nashzotic Cupcake Jun 24, 2018
