4
OnePlus 6 camera issue
  1. saharkaps
    Cupcake Feb 11, 2021
    saharkaps , Feb 11, 2021 :
    my OnePlus 6 camera is not working, it shows blank screen. sometimes it doesn't work with phone camera, sometimes it doesn't work for Snapchat and Instagram too. i tried clearing chache and restarting my phone several times, but nothing is working. It is happening after the recent update.
  2. drl431
    Junior Moderator, Community Hero 2020 Junior Moderator Feb 11, 2021
    drl431 , Feb 11, 2021 :
    Did you clear the cache AND storage for the camera app, before restarting the phone?
    Shailender Sharma and Caomhin like this.
  3. sumitMZ007
    Jelly Bean Feb 11, 2021
    sumitMZ007 , via OnePlus 6 , Feb 11, 2021 :
    Try using Gcam from Google! It takes better photos than stock camera app! And if still your camera doesn't work then it's hardware failure and visit the service center for repair
  4. saadabd2211
    Cupcake Sep 12, 2021
    saadabd2211 , via OnePlus 6 , Sep 12, 2021 :
    I'm having the same issue. Camera doesn't work in any app... Due to this my flash light toggle also displays "camera in use" under it...
    I've tried to clear the cache,.. disabled the camera and restarted the phone... I've also closed the camera service from developers options but issue remains the same
  5. drl431
    Junior Moderator, Community Hero 2020 Junior Moderator Sep 12, 2021
    drl431 , via OnePlus 6 , Sep 12, 2021 :
    Could be that an app you have previously installed is misbehaving and not releasing the camera.
    Shailender Sharma likes this.
  6. 4inepox
    Cupcake Sep 13, 2021
  7. saadabd2211
    Cupcake Sep 15, 2021
    saadabd2211 , via OnePlus 9 , Sep 15, 2021 :
    I have updated my phone to android 11, android 11 beta and then back to asbestos 10 many times and also hard reset the phone multiple times... So I doubt that it's some app
  8. OnePlusRogueOggy
    Eclair Oct 9, 2021
    OnePlusRogueOggy , via OnePlus 6 , Oct 9, 2021 :
    Hi there, I'm having the same issue.
    Camera opens for 2 seconds and then closes without any response.
    Are you facing the same?
    I tried clearing the Cache and Storage data or Camera App, then tried Factory reset 4 times.
    Didn't work, then I reverted back to Android 10, then 9 also, but not resolved.
    It worked completely fine before 11.1.1.1.
  9. M1533764665737
    Cupcake Oct 18, 2021
    M1533764665737 , via OnePlus 6 , Oct 18, 2021 :
    Same problem.Fastreboot,reboot,hard reset every possible thing I've tried.but my camera works for some time. Then again same old black screen.
    And yes after the os update, facing this problem. No hardware problem at all.
  10. Shubhanshu008
    Shubhanshu008 , Oct 18, 2021 :
    Same problem with me...if you find any solution.plz let me know
  11. axel09
    axel09 , Oct 18, 2021 :
    did u resolve the problem? i have just started encountering this issue
    had submitted this issue to the known issue thread . hope someone has a solution
  12. schrome
    Eclair Oct 19, 2021
  13. X1532246425657
    Donut Oct 28, 2021
