OnePlus 6 camera problem via OnePlus 6
  1. Vitthal_Saxena
    Cupcake May 8, 2021
  2. Does!Compute
    KitKat May 8, 2021
    Does!Compute , May 8, 2021 :
    Clear cache and data for the camera app. Disable and re-enable the camera app from Settings.
    Clear cache from recovery
    Caoimhín likes this.
  3. sumitMZ007
    Jelly Bean May 8, 2021
  4. #4
  5. _authenticsara
    Cupcake May 9, 2021
  6. #6
  7. A1550387522048
    Honeycomb May 9, 2021
    A1550387522048 , via OnePlus 6 , May 9, 2021 :
    Sometimes, especially after an update the stock apps can be disorder cause of oldest version incompatibility. Furthermore if you did not restart the device offer updated such as the cam, running problems probably will occure.
    At this case, to clear all datas and updates of app and make reloading the software can be solve the problem. Open app, look to the right corner, tab to : open the explains and choose delete all updates..
    And reload the app latest update from Google Play Store.(or maybe from APK mirror)
    You will see that camera is working perfect.
