Oneplus 6 cellular network signal issue specially in weak signal situation. via OnePlus 6
  1. Rubel7114
    Froyo Sep 21, 2020
    Rubel7114 , via OnePlus 6 , Sep 21, 2020 :
    My oneplus 6 shows network signal but i can't able to call or someone who try to call me, find my number off. This problem occurs more in indoor situation where the network signal is comparatively weak. Sometimes it happens in good signal also.
    So at home, i can't use my phone. It is not network Carrier issue because my Grameen Phone SIM works fine with other phone. I am using this phone for nearly two years at this home but the problem starts from two weeks ago. My other family member also using same carrier SIM without any issue.
    To solve the problem, I changed the SIM slot.
    Reset network. Switch network 2G/4G. Wipe cache. Reset network APN etc. But nothing works.
    It seems like to me, may be my phone's network reception ability becomes weaker so that it can't perform in indoor or week signal area. So I'm confused is it a hardware issue or software bug? Plz help me.
  2. Caomhin
    OnePlus 9 Series Expert Community Expert Sep 22, 2020
    zayn_ys likes this.
  3. Rubel7114
    Froyo Sep 23, 2020
    Rubel7114 , via OnePlus 6 , Sep 23, 2020 :
    Thanks for your comments.
    I installed the diagnosis app it says Signal is good. But the problem is not solved. What you think, is it really a hardware issue? I found many people complaining about the OnePlus 6 network issue.
    What should I do next?
  4. Caomhin
    OnePlus 9 Series Expert Community Expert Sep 23, 2020
    Caomhin , via OnePlus 6T , Sep 23, 2020 :
    Other option is that their is a fault in Android itself or with an app or apps.
    Might be a bit drastic, but have you considered backing up your data and then doing a full Erase All Data factory reset,
    Run the phone with just OOS installed and nothing else, no additional 3rd party apps, for a couple of hours, just to check in case there may be an app or apps causing the issue.
    If it works OK with no additional apps installed. Then reintroduce your apps in stages, just to see if any of them create an issue. If it works fine then it may have been the current installation of Android itself causing a problem
  5. Rubel7114
    Froyo Sep 23, 2020
    Thank you for the suggestion.
    Ok I'll do it in my suitable time and share you the result.
    Hope it will resolve the issue.
    Caoimhín likes this.
  6. Rubel7114
    Froyo Sep 30, 2020
    Rubel7114 , via OnePlus 6 , Sep 30, 2020 :
    Hello, as per your suggestion I have done the factory reset and use the phone without any third party app. But unfortunately the problem isn't solved.
    Now I'm using my OnePlus 6 without any SIM (Grameen Phone), using another phone from Huawei which is 4 years old & working fine with that SIM (Grameen Phone).
  7. Rubel7114
    Froyo Sep 30, 2020
    I have sent you a message, plz check. Its little long to post it here.
  8. Caomhin
    OnePlus 9 Series Expert Community Expert Sep 30, 2020
  9. Istiaque Dollar
    Cupcake Nov 3, 2020
  10. dushyanthvarma
    Eclair Nov 5, 2020
    Rubel7114 likes this.
  11. Istiaque Dollar
    Cupcake Nov 6, 2020
  12. Caomhin
    OnePlus 9 Series Expert Community Expert Nov 6, 2020
    Caomhin , via OnePlus 6T , Nov 6, 2020 :
    Report the issue directly to OnePlus Developers as a Bug report.
    And also contact OnePlus support directly to see if they have more information on your issue. Scroll down the page for contact and online chat details.
    V1612791241100 and Rubel7114 like this.
  13. V1612791241100
    Cupcake Jun 18, 2021
  14. V1612791241100
  15. V1612791241100
    Cupcake Jul 3, 2021
