Oneplus 6 changes MAC adress
  1. woxxu
    Donut Dec 21, 2019
    woxxu , Dec 21, 2019 :
    Hello,
    i have problem with my wifes phone (OP6). After upgrading to Android 10 it does not connect to wifi. I have been digging on its settings and i noticed that MAC adress is changing randomly between two adresses. what is happening? i was sure that MAC adress is constant and permament. my wifi have MAC filtering.
  2. harshit.b.
    Jelly Bean Dec 21, 2019
    ACT43277, Artemus and Bouncer71 like this.
  3. woxxu
    Donut Dec 21, 2019
    Hey, there is no advanced on wifi settings
  4. harshit.b.
    harshit.b. , via OnePlus 6 , Dec 21, 2019 :
    Tap on the wifi network you're connected to, You'll find it over there.
    ACT43277 and drl431 like this.
  5. woxxu
    Donut Dec 21, 2019
    Aaa, ok i was looking in general wifi settings, thanks it worked!
    Artemus, drl431 and harshit.b like this.
  6. ACT43277
    Gingerbread Dec 22, 2019
    ACT43277 , via OnePlus 6T , Dec 22, 2019 :
    Hello, exactly , i also noticed and suffer this same behavior yesterday with this default setting if using Wifi Mac access filtering in the wifi Access Point. A possible suggestion might be to change this default setting in the OS.
  7. RKEDIA
    Cupcake Dec 24, 2019
    RKEDIA , Dec 24, 2019 :
    Hello, Today my one plus 6 has been upgraded to Android 10 by OT updates. I am facing exactly the same issue and it is not working even after i set the advance settings in wifi to "use device Mac Address". Any one facing the same issue? Developers please look at the bug.
  8. brown78
    Donut Dec 25, 2019
    brown78 , Dec 25, 2019 :
    I had the same issue on my rooted device, via terminal I was able to revert the original MAC address. My father in law's OP6 isn't rooted but affected by the same issue - his device has a completely different MAC address now.
