OnePlus 6 charging issue
  1. K1538013858517
    Cupcake Feb 17, 2020
    K1538013858517 , Feb 17, 2020 :
    Hi I am using OP 6 and from past 2 weeks I am facing this issue with charging whenever I plug in for charging the device is not getting charged it is changing continuously from "" charging to charging rapidly "" after a very long time it stabilizes to charging rapidly sometimes I have tried changing ports but the issue is present
  2. Bilalazeem54
    Ice Cream Sandwich Feb 18, 2020
    Artemus. and Caomhin like this.
  3. Master_TC
    Jelly Bean Feb 18, 2020
  4. G_Sharath_Chandran_dSfU
    Cupcake Feb 18, 2020
    G_Sharath_Chandran_dSfU , Feb 18, 2020 :
    Same issue here. Have to unplug and plug multiple times to Rapid charge. Tried other OP6 bricks, different locations and still the same. Shame that the device starts to function like this outside the warranty. The latest software update didn't fix the issue. Can't afford to shell out huge amount to fix this. Better to go for a reliable brand.
  5. G_Sharath_Chandran_dSfU
  6. B1527368872856
    Cupcake Feb 22, 2020
    B1527368872856 , Feb 22, 2020 :
    i am facing the same but mine is not changing at all to rapid charging it is taking 5 to 6 hours to fully charge my phone . tried changing multiple charging places but not working.
  7. Caomhin
    Lollipop Feb 22, 2020
    Caomhin , via OnePlus 6T , Feb 22, 2020 :
    Clean the ports on the phone, charger and both ends of the USB cable with a fine dry toothbrush
  8. B1527368872856
    tried already but no success.. moreover my phone's battery gets down quickly from couple of weeks.
  9. T1548824736362
    Cupcake Feb 23, 2020
    T1548824736362 , Feb 23, 2020 :
    How to get a new Red Cable?
    bcoz my is not being charged through that cable.. the pin has become loose...
  10. Caomhin
    Lollipop Feb 23, 2020
  11. Maxj550
    Eclair Feb 23, 2020
    Maxj550 , via OnePlus 6 , Feb 23, 2020 :
    best way to clean a port is use compressed air. you can damage the connectors using a tooth brush
  12. Maxj550
    Eclair Feb 23, 2020
    It might not be the port, it.could be your fast charge plug has an issue. Try compressed air to blast out the usb port on you plug and you r phone port.
    hope it helps 🤔
  13. Maxj550
    Eclair Feb 23, 2020
    Try Amazon or OnePlus sites.
  14. G_Sharath_Chandran_dSfU
    G_Sharath_Chandran_dSfU , Feb 23, 2020 :
    Even tried a different OP6 charger. Only thing left to do is to try blasting compressed air in the charging port of the phone. Hope that works.
  15. K1538013858517
    Cupcake Feb 24, 2020
    K1538013858517 , Feb 24, 2020 :
    Yess I went to the OnePlus service center they said that the adaptor is faulty .. didn't expected that the adaptor will turn faulty merely after a year
