plbafna , via OnePlus 6 , Jan 9, 2021 : Slow charging happening. Fast charging is not happening. What could be the issue ?
Dresa91 , Jan 9, 2021 : Hey, did you clean the USB port of your device? Did you try using another socket, charger and cable? Can you check charger and cable with another OnePlus device?
mojoyoyo77 , Jan 9, 2021 : As you have been asked before, and to help other users who may possibly face the same problem, it would be good to know which solution worked
