12
OnePlus 6 double tap to wake up problem
  1. Harpreet541999
    Gingerbread May 27, 2018
  2. ashgtx
    Donut May 27, 2018
  3. B1527346283658
    Cupcake May 27, 2018
    MentalDraco likes this.
  4. rjkulkarni2001
    Cupcake May 28, 2018
  5. nid92
    dhaval_kasetiya likes this.
  6. sunnysangtani
    Eclair May 28, 2018
  7. MatG-DK
    Gingerbread May 28, 2018
    MatG-DK , May 28, 2018 :
    Yes, i got same problem.
    It's like you have to double tap two or three times,
    Hope for a fix in next update
  8. kvnreddy
    Froyo May 29, 2018
  9. Mobilemachine007
    Froyo May 29, 2018
  10. MatG-DK
    Gingerbread May 29, 2018
    MatG-DK , May 29, 2018 :
    Mobilemachine007
    where to find double tap to lock screen..because I could not find it in my home page setting
    Put finger on an empty space on screen and hold it, and home screen settings will pop up in lower right corner.
    KeithW8 and imgagan like this.
  11. biglex91
    Cupcake May 29, 2018
    biglex91 , May 29, 2018 :
    Same problem...i have to double tap 2 3 times for the function to work... Hope they fix this minor bug
  12. Mobilemachine007
    Froyo May 29, 2018
    MatG-DK likes this.
  13. Donev
  14. damolitoy
    Gingerbread May 31, 2018
  15. nobraindk
    Froyo May 31, 2018
    nobraindk , May 31, 2018 :
    maybe pocket mode prevents it? disabling and rebooting fixes it but without pocket mode it can be woken up itself in pocket.
  16. Dark_Matrix_Guru
    Ice Cream Sandwich May 31, 2018
  17. S1527612901649
    Cupcake May 31, 2018
  18. avibored
    Honeycomb May 31, 2018
  19. João Figueiredo
    João Figueiredo , May 31, 2018 :
    Work every time for me.Did you remove the protection or other problem than the double tap?Could be a problem in the sensor. Do you know how to calibrate the monitor?Try to do so if you notice other problems that double tap
  20. ksivage
    Donut May 31, 2018
    ksivage , May 31, 2018 :
    I have the same issue. I also wish there was a way to disable the vibration on the double tap
