Oneplus 6 general questions / request for development
  1. mouldy Donut Aug 9, 2018
    mouldy, Aug 9, 2018 :
    Hello i just bought Oneplus 6. Transition from phone Zenfone 5, at first I must say its very nice device, but I have a few questions or maybe request for development.
    1, Audio
    In a lot of reviews, the speaker is a weak spot of Oneplus 6, I do not think it's so bad. But I know about the mode for stereo. Is it possible to implement it to official update? Does anyone use this mode? Is it a problem to make it work in official android?
    Audio quality from jack / bluetooth.
    There are opinions, that the audio output from oneplus 6 is not perfect. But it is possible to improve it with Viper audio (XDA forum). Next thing to implement to official android? Why not?
    Dirac Audio - What is it? It's functional?
    This is the biggest weakspot in reviews. So make it operational in the next update is a good idea right?
    2,battery modes
    From Asus Zenfone 5 I was used to battery modes, there were a battery savers with a limit on the number of running applications, CPU clock etc... Is it possible to add it to Oneplus 6?
    3, display brightness
    I read about Amoled HBM technology, on the automatic regulation of brightness is possible to boost up brightness to 650nits. But is it active in 5.1.9?
    debanikghosh likes this.
  2. ngydat Jelly Bean Aug 9, 2018
    ngydat, Aug 9, 2018 :
    You should probably post this in the feedback section of the forum https://forums.oneplus.com/forums/community-feedback/.
    cdnfarmer likes this.
  3. mouldy Donut Aug 10, 2018
    mouldy, Aug 10, 2018 :
    Posted to feedback.
    Next thing: bokeh
    What does it means those icons in portrait mode?
    circle, star...
  4. mouldy Donut Aug 10, 2018
  5. idkwhoiam322 Marshmallow Aug 10, 2018
    idkwhoiam322, Aug 10, 2018 :
    Hardware related, an earpiece can not be safely made to act as a stereo secondary speaker, it would've been done already otherwise.
    Because OxygenOS is not a custom rom and you can't simply add things as you please.
    Google is a very powerful search engine.
    https://www.dirac.com/
    All suggestions and feedback go here:
    Just like the standard Android battery saver mode?
    No, it isn't enabled and even if it was, probably would be for a limited time period. Drop it in feedback as a feature request:
    Nick 59 likes this.
  6. idkwhoiam322 Marshmallow Aug 10, 2018
    Could you post a screenshot?
    Please be patient, people here are users just like you and are doing this completely for free.
    Nick 59 and otto2 like this.
  7. Kytharsis Lollipop Aug 10, 2018
    Kytharsis, Aug 10, 2018 :
    Those icons make lights caught in the bokeh appear as those shapes.
  8. MobammedAsifAhmed Cupcake Aug 10, 2018
    MobammedAsifAhmed, Aug 10, 2018 :
    Hi, oneplus 6 is very good mobile.
    I have used Xiomi Redmi Note 4, in that we have one handed mode, where screen size reduces to use with one hand.
    can this be possible in this mobile to integrate???
    it will be very helpful.
    thank you
  9. Kytharsis Lollipop Aug 10, 2018
    Maybe in the future?
    Nick 59 likes this.
  10. MobammedAsifAhmed Cupcake Aug 10, 2018
  11. Kytharsis Lollipop Aug 10, 2018
    I can't do anything.
    Nick 59 likes this.
  12. adamrex Cupcake Aug 10, 2018
  13. Kytharsis Lollipop Aug 10, 2018
    Depends on what needs fixing.
  14. mouldy Donut Aug 12, 2018
    mouldy, Aug 12, 2018 :
    I dont think that, look at Huawei P20 and P20Pro. P20 Pro has stereo mode, but the ear speakers are probably the same.
    If it is possible to make it with some XDA mode, so that must be simply to add.
    Yes tried that, but nothing definite.
    https://www.xda-developers.com/oneplus-6-display-analysis-compared-oneplus-5t/
    Probably it was/is.
  15. idkwhoiam322 Marshmallow Aug 12, 2018
    idkwhoiam322, Aug 12, 2018 :
    "probably"
    No such thing. It's either designed to work as a speaker as well as an earpiece or just an ear piece.
    No, it isn't. You can't just merge commits as you please as an OEM. You have to do stuff on your own when it comes to these things, consider their feasibility, long term effects and how easy it will be to maintain on future devices, etc. etc. And tbh, these mods are largely placebo.
    Nick 59 and Kytharsis like this.
  16. mouldy Donut Aug 12, 2018
    Stereo mode works, just look at the XDA. The only thing is, do not exceed the limit
  17. Kytharsis Lollipop Aug 12, 2018
    Kytharsis, Aug 12, 2018 :
    It works but at the cost of damaging the earpiece, even if you don't "exceed the limit".
    Betamixz, Nick 59 and idkwhoiam322 like this.
  18. idkwhoiam322 Marshmallow Aug 12, 2018
    They all have a disclaimer to not blame the creator of the mod if your earpiece gets damaged for a reason lol
    It does and will damage it over time.
    Betamixz, Nick 59 and Kytharsis like this.
  19. mouldy Donut Aug 12, 2018
    Source of this? Yes I think, It needs to be tested, but is it possible.
    Another insight:
    Poor sound quality when recording video in WhatsApp.
  20. ManeeshKumar Honeycomb Aug 13, 2018
    ManeeshKumar, Aug 13, 2018 :
    Anyone noticed that the front camera has softening even when softening is off ....
    This problem was not there in 5.1.8 ...
    Check out the latest GCam Mod....Front cam images are far better than stock cam...
