2
OnePlus 6 heavy battery drain
  1. Mramji
    Donut Sep 26, 2020
    Mramji , Sep 26, 2020 :
    My phone has been heavily draining battery over the last few weeks, and I'm not sure why. I don't remember if their was even an update.
    Is anyone else experiencing this? or can someone from the OnePlus team clarify if their is anything I can do about it. I know it's a slightly older device, but it has never caused me an issue. (screenshots below)
    Also, if someone could enlighten me on the battery percentage for usage. nothing adds up at all.
    Srínívas Sñ and AZGARDS like this.
  2. Dinesh 6004
    Eclair Sep 26, 2020
  3. ItsRavi25
    Ice Cream Sandwich Sep 27, 2020
    ItsRavi25 , via OnePlus 6T , Sep 27, 2020 :
    For battery draining and heating issue try this.
    You can calibrate to enhance your battery life
    For battery draining you should follow this to calibrate..
    Goto settings >App and notifications>Click on three dot in right corner>Reset app preference.
    To Optimize the phone, clear your recent apps, also set 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    Thanks to @Caomhin 😇...
    Mramji and Caomhin like this.
  4. Kumar Brijesh
    Froyo Sep 27, 2020
  5. riyaz7861
    Eclair Sep 29, 2020
  6. O1559678203904
    Cupcake Oct 10, 2020
