2
Network/Connectivity Oneplus 6 loses 4G/H+ Network connection during standby, switches back to 3G but still offline.
  1. sahilangz
    Eclair Jun 5, 2018
    sahilangz , Jun 5, 2018 :
    You can see voice service : emergency calls only
    And other .
  2. arshdeepsingh608
    Froyo Jun 5, 2018
    arshdeepsingh608 , Jun 5, 2018 :
    Then try for LTE/WCDMA.
  3. chaitanyakhaitan
    Honeycomb Jun 5, 2018
    chaitanyakhaitan , Jun 5, 2018 :
    Wow send in your new phone for repair, that's what we want to do now.
    How can they even suggest such a thing?
    Let me know how you go about it.
  4. sahilangz
    Eclair Jun 5, 2018
    what should we do , we should wait or what . i know how they handle phone in repair . dont want to give them .
  5. P1528184984026
    Cupcake Jun 5, 2018
    P1528184984026 , Jun 5, 2018 :
    Hi just got one plus 6 and I m facing network issue Sim 1i have jio and sum 2 have Airtel. when I call or o received calls on Airtel voice not clear and some times it's clear what is the solution for the same . can I return the phone? or shall I wait for some updates.
    thanks
  6. Y1527151126111
    Froyo Jun 5, 2018
  7. love1plus1specs
    Gingerbread Jun 9, 2018
  8. kamal.kantech
    Eclair Jun 9, 2018
    kamal.kantech , Jun 9, 2018 :
    seems it had some problem in the network section very seldonm the the SMS and calling features gets disabled. need a complete reboot to fix the issue.
  9. jasonarima
    Honeycomb Jun 9, 2018
    jasonarima , Jun 9, 2018 :
    5.1.6 seems just release. Let's wait and see whether it can improve call drop issues.
  10. BigM
    BigM , Jun 9, 2018 :
    I have just received a notification that OxygenOS 5.1.6 is available and there are listed some fixes for 4G problems. Let's hope this solves out problem as well.
    I will download, update and test later that day. I will let you know if it works.
  11. P1528184984026
    Cupcake Jun 9, 2018
  12. sahilangz
    Eclair Jun 9, 2018
    sahilangz , Jun 9, 2018 :
    you will soon get . it get rolled out in batches . I am also waiting.
  13. chaitanyakhaitan
    chaitanyakhaitan , Jun 9, 2018 :
    Please keep us updated, and really hope that the problem gets solved.
    Wish you luck
  14. chaitanyakhaitan
    Any update??
  15. BigM
    Just installed 5.1.6 and directly after the update the problem occurred again.
    So 5.1.6 does not change anything, at least for me :-(
  16. jasonarima
  17. BigM
    Please see first post in this thread, same problem is still there in 5.1.6.
  18. sahilangz
    Eclair Jun 9, 2018
    after updating to 5.1.6 , same problem is pertaining. still both the Sim are inserted and no one is showing signal . emergency calls only . #shitbox
    #38
  19. chaitanyakhaitan
    Please restart a couple of times and use for some more time and update.
    As I am facing the exact same issue as yours, don't have very high hopes now.
    Thanks
    #39
  20. G1528580563269
    Cupcake Jun 9, 2018
    G1528580563269 , Jun 9, 2018 :
    I'm facing network issue with both my Airtel and Vodafone sim in my flat. In my office it is working perfectly fine. earlier I used to use an samsubg 3g phone and I had faced no network issues with that. Sometime situation is getting as worse that I need to take out the sim card and re insert it to make a call altough network bar is showing as full. Please let me know if some else is also fscing the same
    #40
