6
oneplus 6 LTE/4G problem in Holland
  1. witte270 Cupcake May 28, 2018
    witte270, May 28, 2018 :
    hey guys,
    just wondering if anyone was experiencing the same issue as I am, I can't connect to the 4G networks in the Netherlands. I tried to change the SIM slots (from 1 to slot 2), but that doesn't resolve the issue. am I the only one or is someone else also experiencing this particular problem?
  2. pendragon Gingerbread May 28, 2018
    pendragon, May 28, 2018 :
    I'm in the Netherlands and for me 4G is working fine. I'm on KPN. What's your provider?
    Jkid and KoVeN like this.
  3. Sergio Sonego Froyo May 29, 2018
    Sergio Sonego, May 29, 2018 :
    I am from Paraguay, SAME HERE! 4G is not working, I got 2 SIMs, different companies, neither work. The phone is faulty: My SIMs work in my Oneplus 3t AND other phones, but NOT IN MY BRAND NEW OP 6!!!:mad::mad::mad:
    Vicmaniaco, ricardoromob and KoVeN like this.
  4. KoVeN Gingerbread May 29, 2018
  5. kistedu Eclair May 29, 2018
    pendragon likes this.
  6. ricardoromob Donut May 30, 2018
  7. abalipadi Cupcake May 30, 2018
    abalipadi, May 30, 2018 :
    I am having issues with ATT in USA. I get only 3G and no 4G. Oneplus technicians were unable to help and neither were ATT folks. So not sure how i can get this solved. Anyone having the same issues?
    KoVeN likes this.
  8. witte270 Cupcake May 30, 2018
    witte270, May 30, 2018 :
    currently using the TELE2 network, on my OnePlus 3T everything worked fine.
  9. Rpeezy2 Cupcake May 30, 2018
  10. Medxion007 Donut May 30, 2018
    Medxion007, May 30, 2018 :
    I am in the Netherlands. I have 2 sims both KPN and working on 4g. Only thing is when i go to another country like belgium it doesn't switch to a provider whit 4g and roaming doesn't work :(.
  11. markiebiboy Ice Cream Sandwich May 31, 2018
    markiebiboy, May 31, 2018 :
    Same issue here on T-mobile Netherlands here!
  12. witte270 Cupcake May 31, 2018
    witte270, May 31, 2018 :
    I believe TELE2 uses the T-Mobile network.
  13. ooPuFFoo Cupcake May 31, 2018
    ooPuFFoo, May 31, 2018 :
    I couldnt get LTE running on mine, in US on AT&T. Tried various things like moving the Sim, and redoing APN. I came from a NOTE4, so the Sim card was different size and i couldn't just put it in OP6. The last thing done was have the Note4's IMEI # associated with the Nano Sim i got from AT&T. And Now I have LTE. One rep suggested that the IMEI # range for the OnePlus6 are not in AT&T's Database yet, I would venture to guess that is same problem with ANYONE not getting LTE but SHOULD be. Also used the NXTGENPHONE APN which is what my Note4 used. So, have ATT or any carrier yawl having an issue getting LTE on, to connect your OLD phone's (that had LTE) IMEI # to the new nano Sim card.
  14. F_Karl_Koza_NiZW Froyo Jun 1, 2018
    F_Karl_Koza_NiZW, Jun 1, 2018 :
    Hey Guys,
    Same issue here in France! 4G+ (LTE) worked fine when I got my OP6, then I installed 5.1.5 and it lost 4G, only H+ available, which is a better 3G. Contacted Support twice, 1st they did not already know, 2nd time they confirmed it's a bug of 5.1.5. Hopefully there's a bugfix soon
    Vicmaniaco and KoVeN like this.
  15. Leondes Cupcake Jun 3, 2018
    Leondes, Jun 3, 2018 :
    Same un México. i usted to use OP 5 and had no problem with 4G at all. Is there a way to contact OP directly? i mean we are a lot of people with this issue...
    rrubio999 likes this.
  16. jasonarima Honeycomb Jun 4, 2018
    jasonarima, Jun 4, 2018 :
    For AT&T, it is known that you should not use OP's IMEI to register your SIM card.
    You can ask the customer service to change registered IMEI with your old phone.
  17. troy Froyo Jun 4, 2018
  18. LUIS DE PAZ Cupcake Jun 4, 2018
  19. galaxylatino Eclair Jun 4, 2018
    dalbin5jr likes this.
  20. Frits_Schipper Eclair Jun 4, 2018
