7
oneplus 6 LTE/4G problem in Holland
  1. H1528013081747
    Cupcake Jun 11, 2018
    H1528013081747 , Jun 11, 2018 :
    Independiente de esos procesos el celular tiene un problema en banda 4. Después de la homologación no te va impedir q registre 3g o 4g.
    hay q esperar la actualización del software
    #81
    Gotischer likes this.
  2. Gotischer
    Eclair Jun 11, 2018
    Gotischer , Jun 11, 2018 :
    gracias por la información, igual cuando pregunté a tigo yo no sabía que el celular ya estaba homologado y se me fueron por la tangente con eso
    #82
  3. Kb_79
    Gingerbread Jun 11, 2018
    #83
  4. Jawe1212
    Eclair Jun 11, 2018
    #84
  5. Jawe1212
    Eclair Jun 11, 2018
    #85
    juanjonovoa likes this.
  6. Gotischer
    Eclair Jun 11, 2018
    Por cierto contacté con el soporte de oneplus y crearon un ticket para hacerle seguimiento al problema con la banda 4
    #86
  7. michatl
    Cupcake Jun 12, 2018
    #87
  8. Sergio Sonego
    Froyo Jun 15, 2018
    Sergio Sonego , Jun 15, 2018 :
    Hi everyone suffering from 4G issues!
    GOOD NEWS! All of you, that like me have problems with 4G in your phones, I want to tell you A SOLUTION IS COMING! (not winter, A SOLUTION :-D )
    Today I received the honor to test part of the new upcoming OOS update an I can tell THE FIX WORKS!
    Don't loose time trying multiple things like I did, flashing, updating, downgrading, etc etc, just BE PATIENT!
    I am running this fix for some hours and until now no problems at all!
    Don´t know when it will become available, I would lie if I tell you, but unofficially I read that in 2 weeks or so.
    After this said, I would like to ask you to not flood support asking for the patch, it is coming soon, evenly more polished that the one I received today, AND IT RESOLVES THE ISSUE (at least for me it did, and as I saw in various posts, apparently all of us were in the same boat).
    I will be honest to you, I was VERY pissed off with this issue, and started a RMA for replacement or refund, but then Celia, a support contact from OnePlus told me to take a deep breath and wait. I trusted her, canceled my request AND KNOW I AM VERY HAPPY I DID! OP 6 is as awesome as I wanted it to be!
    That's all friends!
    #88
    H1528013081747 likes this.
  9. michatl
    Cupcake Jun 15, 2018
    michatl , Jun 15, 2018 :
    Same for me, OnePlus (Celia) send me a ROM with the fix for the 4g issue, it works great, this Is a software bug not a hardware problem, the problem will be fixed on the next update. be patient
    #89
  10. H1528013081747
    H1528013081747 , Jun 15, 2018 :
    thanks we wait. i opened a case and one support suggested a hard phone reset.
    i prefer wait the sw update
    #90
  11. michatl
    Is a bug the reset don't work you have to wait the fix in a new release.
    #91
  12. TacoJames
    TacoJames , Jun 15, 2018 :
    Hey! Could you send us a link with the rom they sent you?? It would be very much appreciated!!
    #92
  13. Sergio Sonego
    Froyo Jun 15, 2018
    #93
  14. MarcelLamers
    MarcelLamers , Jun 15, 2018 :
    Hi, 4G connection on Vodafone Nederland is perfect. If You are traveling tot Belgium check your settings andere choose roaming.
    #94
  15. H1528013081747
    Cupcake Jun 17, 2018
    #95
  16. H1528013081747
    H1528013081747 , Jun 17, 2018 :
    ya lo arreglaron, 5.1.8, me funcionó con Movistar
    #96
  17. michatl
    #97
  18. H1528013081747
    si, me llegó la actualización por la aplicación default del teléfono y funcióna el LTE banda 4
    #98
  19. michatl
    michatl , Jun 17, 2018 :
    genial a mí me habían mandado la 5.1.6 con un parche luego de que abrí el caso
    #99
  20. H1528013081747
    yo abrí un caso, y me mandaron a hacer un reset de teléfono , les dije q no lo iba hacer y que necesitaba una solución efectiva y hoy me dijeron que actualizará que eso arreglaba el problema
