Oneplus 6 Network problem
  1. Rasin_Zaman Cupcake Jul 20, 2019
    Rasin_Zaman, Jul 20, 2019 :
    Recently I am facing some serious network issues on my oneplus 6. Sometimes it shows network signal but I can't call or text anyone. Nobody can also call or text me. they find number is switched off. Again Sometimes it doesn’t even show any network signal, goes on emergency mode. Sometimes switching between 2g or 2g/3g/4g bring some benifits. I tried network reset but it doesn’t make any difference. Please help is needed.
    Thanks in advance.
    pankaj19833 likes this.
  2. Priyanshu Sharma Jelly Bean Jul 20, 2019
  3. Rasin_Zaman Cupcake Jul 21, 2019
    Rasin_Zaman, Jul 21, 2019 :
    Tried other sim but result all the same. Even my current sim using in this device are running in other devices perfectly.
    I am using Oxygen OS version 9.0.7
  4. Priyanshu Sharma Jelly Bean Jul 21, 2019
    Priyanshu Sharma, Jul 21, 2019 :
    You can submit your bug using feedback tool in Community app or just use this link-
  5. Priyanshu Sharma Jelly Bean Jul 21, 2019
    Try resetting network settings-
    Settings>>System>>Reset Option>>Reset Wifi, Mobile and Bluetooth
