Other Oneplus 6 not starting up
  1. Sam69shaikh
    Cupcake Oct 1, 2019
    Sam69shaikh , Oct 1, 2019 :
    I was checking insta and suddenly it got switched off battery was 60% , tried long pressing power button, plugging charger, connecting to pc, but nothing is working its just dead please help.......
  2. JAGADISH BHATTA
    Jelly Bean Oct 1, 2019
    JAGADISH BHATTA , Oct 1, 2019 :
    I am not sure but seems like your phone's motherboard is dead do check with service center
    Caomhin and Artemus. like this.
  3. #3
  4. Caomhin
    Marshmallow Aug 8, 2020
    Caomhin , via OnePlus 6T , Aug 8, 2020 :
    Leave the phone plugged in for about an hour to see if it will charge. If not try Cleaning the ports on the phone, charger and both ends of the USB cable with a fine dry toothbrush or non conductive wooden or plastic toothpick carefully.
    Then try Safe Mode. Method 2 may work for you if it will start
    Try going into Safe Mode. And remove any recent app installs or updates that may be causing the issue. Also backup all your data while in Safe mode.
    Method 1
    Press the power button to bring up the power menu, now long press Power Off option you will get the option to boot into safe mode. Select OK
    Method 2
    Turn off your Android device by holding the power button and selecting the power off option from the menu.
    Once your device has been powered off, long press the power button to turn it back on and wait till you see the device manufacturer or the Android logo.
    Once you see the logo, press and hold the volume down button until your device reboots.
    Release the power button once your device has rebooted and you will now be entered into the safe mode.
    To get out of Safe Mode
    Hold the power button on your device until you get the power off menu.
    Select the restart option from the menu.
    Your device will now be rebooted and exit from the safe mode and boot into the normal mode.
    U1569942842631 likes this.
