6
OnePlus 6 notification bar bug during call and also call problems (*important)
  1. Akshat2793 Ice Cream Sandwich Oct 9, 2018
    Akshat2793, Oct 9, 2018 :
    When ever I'm on a call, it's hard to pull down the notification bar from top, it keeps going back up. It's happening on Android 9 Pie.
    And also when I receive a call (when I'm not using the phone), I'm unable to use the fingerprint scanner nor go to the homescreen. Only after I pick up the call or cancel it, I can go to the homescreen. Can someone please reciprocate these problems and confirm if you're device on Android P (stable) is facing such issues.
  2. Sourciety Froyo Oct 9, 2018
    Sourciety, Oct 9, 2018 :
    I'm on stable 9, and I have no issues like these. Whenever I am called, I just swipe the back gesture and the pending call disappears in the bottom area until the other person hangs up.
    Did you update your Stable from a Beta version, or straight from 8?
  3. Akshat2793 Ice Cream Sandwich Oct 9, 2018
    I updated it from Stable Oreo, not beta l. Can you try pulling down the notification bar when you're on the call? It keeps going back up.
    O1529035631954 likes this.
  4. Sourciety Froyo Oct 9, 2018
    I'm not having this issue. I called my voicemail and both home gestures, back gestures and notification bar keep working. I have however noticed that I do need to drag it down a bit further than normal, otherwise it does go back up.
    Akshat2793 likes this.
  5. B_Wrath Lollipop Oct 9, 2018
    B_Wrath, Oct 9, 2018 :
    That's how things are in Pie... I guess it had been done to avoid accidental touches of notification icons while on call..
    That's how it has been for a very long time... Nothing new... It's how android works...
    Being at your level and not searching and reading the forum saddens me...
    Please don't create redundant threads as you could have had these answers with a simple search....
  6. W1527231815972 Cupcake Oct 9, 2018
    W1527231815972, Oct 9, 2018 :
    I'm also having this issue. Its really tough to pull the notification panel down. Also all of my calls start in pocket mode. Also double tap feature stops working while on call.
    G_Adarsh_Ps_qfUO and Akshat2793 like this.
  7. Akshat2793 Ice Cream Sandwich Oct 9, 2018
  8. Herve Jeannin Cupcake Oct 11, 2018
    Herve Jeannin, Oct 11, 2018 :
    I have exactly the same problem. Unable to use the phone now. It should be quickly repair, because I'm not actually able to use the phone when I receive a call.
    G_Adarsh_Ps_qfUO likes this.
  9. Herve Jeannin Cupcake Oct 11, 2018
    Sorry but I don't agree with you. My phone had a good work before I changed my OS version with pie. When the phone called, I saw the screen and was able to accept or refuse the call. Now it's impossible except press on the right button to refuse the call.
  10. B_Wrath Lollipop Oct 11, 2018
    B_Wrath, Oct 11, 2018 :
    Are you talking about the same thing which I have told???
  11. neelanjanacharya Cupcake Oct 11, 2018
    neelanjanacharya, Oct 11, 2018 :
    I am also facing the same issue. Whenever I am on a call, it seems impossible to pull down the notification shade.
  12. Herve Jeannin Cupcake Oct 11, 2018
    I asked to Technical support an answer to my issue because on forum we are unable to find solution. Just people who said "search during hours and hours to find something." Sorry I can't spend hours to maybe find the solution. I just need to have a quick fix. This is the problem with brands without customer support line.
  13. UltraZboy Froyo Oct 17, 2018
