3
oneplus 6 notification led not blinking after android 10 update
  1. K1538329783365
    Cupcake Dec 23, 2019
    K1538329783365 , Dec 23, 2019 :
    LED blinking has been stopped working after upgrading to android 10 , this update was done through official update from one plus.
    I have checked the settings all the options are enabled but still I'm not getting LED blinking.
    kindly note this isn't working especially for WhatsApp before I was getting white led notification.
    iamrj, nsaismruti and sidd29 like this.
  2. andrerdxd
    Cupcake Dec 26, 2019
    andrerdxd , Dec 26, 2019 :
    i have the same issue, no LED blinking neither vibration notifications for messages like snapchat, whatsapp or messenger...
  3. _MarcoJ
    Eclair Dec 26, 2019
    _MarcoJ , Dec 26, 2019 :
    If messages are received when the screen is on, LED will not blink (even when the screen goes off).
    If messages are received when the screen is off, LED will blink.
  4. andrerdxd
    Cupcake Dec 28, 2019
    andrerdxd , Dec 28, 2019 :
    even with screen off LED wont blink for snapchat or whatsapp, only messenger. On android 9.0.9 it would blink yellow for snapchat messages, blue for whatsapp and green for messenger, now in 10.0.3 only blinks the green for messenger and nothing to the others.
    DrJMun likes this.
  5. nsaismruti
    Cupcake Jan 21, 2020
    nsaismruti , Jan 21, 2020 :
    Same problem here
  6. Maverick2.0
    KitKat Jan 21, 2020
    Maverick2.0 , Jan 21, 2020 :
    I have the same issue. I
    Notification LED doesn't blink after missed calls.
  7. nsaismruti
    Exactly same issue here after missed call no notification light.
    Maverick2.0 likes this.
  8. D1556713067934
    Cupcake Jan 22, 2020
  9. cgeromi
    Cupcake Feb 6, 2020
    cgeromi , Feb 6, 2020 :
    This is an on-going issue that I have dealt with since I got my OP6. I've had the OP1, OP3 and now the 6. I am super disappointed in the OP6 and Oxygen OS 9 or 10. Notification light and notifications in general for many apps (Outlooks, Hangouts, Slack, and others) never show the notification light. I've tried every setting from here to kingdom come to no avail.
    I've wondered if LineageOS would fix the issue but don't feel like going through the process of installing the ROM and risking the phone errors out and all that nonsense.
    OnePlus please take a look at these issues and come up with a FIX!! You nailed it with the OP1 and OP3, don't get lazy now that you're a main stream smart phone provider.
  10. DrJMun
    KitKat Feb 6, 2020
  11. cgeromi
    Cupcake Feb 12, 2020
    cgeromi , Feb 12, 2020 :
    Flashed LineageOS today and notification light works perfect for ALL apps.
    OnePlus you absolutely suck with Oxygen!
    _MarcoJ likes this.
  12. _MarcoJ
    Eclair Feb 12, 2020
    _MarcoJ , Feb 12, 2020 :
    Even a third party amateur work works better than OxygenOS. What a pity!
  13. tide1109
    Ice Cream Sandwich Feb 12, 2020
    tide1109 , via OnePlus 6 , Feb 12, 2020 :
    What happens while charging?
    The led should light up permanently in red (default) in normal charging or in blue while Dash/Fast charging.
  14. iamrj
    Gingerbread Feb 12, 2020
    iamrj , via OnePlus 6 , Feb 12, 2020 :
    Indeed, I just checked led is not blinking wasn't aware thus old version of OxygenOS 5 & 9 had all function worked properly. People are happy getting new updates but at the same time many function has been remove or disappeared from oneplus devices.
  15. cgeromi
    Cupcake Feb 14, 2020
    cgeromi , Feb 14, 2020 :
    Not having the notification light blink when the screen is off when a notification is received angers me more than anything in regards to OxygenOS. Up until that point I always had good things to say about it. But, when you take away a key feature of Android that separates it from Apple's walled garden of poop and honey, you have to fix it!!
    OnePlus I BEG you to please fix this bug. On your latest update, the notification light would not blink for the following apps:
    • Outlook
    • Hangouts
    • Voice
    • Slack
    • MS Teams
    I tried every setting, nothing. I also used a third party app like Pulse, but that just sucked. Made the notification light fluky at best.
    Get your act together and fix this. This is an intrinsic part of our phones!
  16. DrJMun
    KitKat Feb 15, 2020
    Kytharsis and Maverick2.0 like this.
  17. DrJMun
    KitKat Feb 15, 2020
    DrJMun , Feb 15, 2020 :
    That's good to know, certainly makes it to be an Oxygen 10.3.1 problem. Is LineageOS up to Android 10?
  18. cgeromi
    Cupcake Feb 16, 2020
  19. cgeromi
    Cupcake Feb 19, 2020
    cgeromi , Feb 19, 2020 :
    I don't think the developers at OnePlus give two craps about notifications. I work as an integration specialist for an eLearning company and I just cant phathom how OnePlus let this one slip through the cracks. I understand that each app maker has variations in there code, but OnePlus should have thoroughly tested a plethora of commonly used apps before deploying the update. They are taking the money and running at this point. They need to stop rushing updates and go back to their OnePlus One roots!!
  20. DrJMun
    KitKat Feb 19, 2020
