Oneplus 6 or Huawei P20 pro
  1. G_Ahamed_Sahadh_vjee
    Froyo Jun 28, 2018
    G_Ahamed_Sahadh_vjee , Jun 28, 2018 :
    Guys, I'm currently using Oneplus 5.
    I'm planning to upgrade to a newer device.
    Help me decide which phone should I be buying?
    Oneplus 6 or Huawei p20 pro?
    My priorities are:
    1. Camera (Especially Portrait Mode)
    2. Performance
    3. Battery
    Please guide me!
    Don't take me wrong, I'm a Oneolus fan too.
  2. Javed
    Cupcake Jun 28, 2018
    Javed , Jun 28, 2018 :
    Hello,
    If you are keen on camera, there is no real need for second thought p20 pro leads it significantly.
    Performance of both phones are almost in the same circle.
    Battery seems a bit better in one plus 6.
    Cheers.
  3. Kartik chowdary
    Froyo Jun 28, 2018
    Kartik chowdary , Jun 28, 2018 :
    Huawei P20 pro of course..
    Camera in Huawei is excellent..
    Battery life is also better than one plus 6..
    Performance both are similar..
    Go for huawei..
  4. Lfcheng
    Gingerbread Jun 28, 2018
  5. ashwin6004
    Honeycomb Jun 28, 2018
  6. Terryruiz
    Ice Cream Sandwich Jun 28, 2018
  7. RamQ
    Froyo Jun 28, 2018
    RamQ , Jun 28, 2018 :
    In terms of performance... the oneplus 6 chipset is a generation newer.. and it will serve you much better in the future in addition the adreno 630 in the oneplus 6 is way more powerful than the mali found in the Huawei.. so yea if you're a heavy user I recommend the oneplus 6
    Battery is about the same you won't be disappointed with either of them out of the box, but on the long run Huawei batteries are known for degrading and losing capacity quickly.
    In terms of the camera both of them perform really great in good lightning conditions and you won't notice any difference, in low light though... the P20 manages to capture with slightly lower noise levels than the oneplus 6.... but the oneplus handles the highlights better...
    Both of them take good portrait shots with great edge detection but images turn out really different... the p20 has less details on people's faces, it's warmer overall, and the oneplus handles skin tones better... you can checkout camera shootouts and see which one do you prefer...
    I tried both smartphones and decided to stick with the oneplus 6 because of many reasons but mainly cuz I prefer near stock android...
    so it all comes down to personal preference at the end
    Spcland12, Betamixz, asb0410 and 2 others like this.
  8. bart877ie
    bart877ie , Jun 28, 2018 :
    Howdy, P20pro is twice expensive. My wife is after buying herself OP6 silk White and I am OP5JCC have to say that camera in latest device is very good. However since oil effect was reduced I have no complaints to my OP5 neither. But the screen and design of OP6 is top notch. Overall experience isn't noticeable with a naked eye. OP5 is still super fast.
    G_Ahamed_Sahadh_vjee likes this.
  9. A1529951309228
    Donut Jun 28, 2018
    A1529951309228 , Jun 28, 2018 :
    p20 pro
    better camera
    larger battery
    more expensive
    slower chip (most likely won't be felt in day to day usage)
    less ram
    oneplus
    better screen
    faster
    more ram
    cheaper
    If you prioritize camera then the p20 is the way to go, hands down. Also the battery life is better. I can't really see any more advantages of the p20. My two cents
  10. G_Ahamed_Sahadh_vjee
    Froyo Jul 2, 2018
  11. DARTH 007
    KitKat Jul 2, 2018
    DARTH 007 , Jul 2, 2018 :
    portrait mode is bad.front cam portrait is horrible.
    camera app will hang sometimes.
    slo-mo is just about average.
    under proper lights outdoors pictures will be punchy and colourful.
    battery - horrible after the update.abt 2 hrs less sot after the last update.
    performance - under utilised SD845 chip with poor software implementation.call drops still happening,screwed up contacts display,don't fall for the speed up need slogan.
    stay away from both phones and buy a better one.
    V1527255369052 likes this.
  12. yubarajshome
    Cupcake Jul 2, 2018
  13. G_reddybabu_tirupathi_QT
    Cupcake Jul 2, 2018
  14. archit1302
    Donut Jul 2, 2018
    archit1302 , Jul 2, 2018 :
    Camera Is Better On P20 Pro
    Performance Is Pretty Much The Same
    Battery seems better on Op6 and it has dash charge
    OnePlus 6 Costs less though than the P20 Pro ,And you are a OnePlus fan
    If I were you I would get OnePlus 6
    Although you don't really need to upgrade it's kind ND of a waste of money since op5 is a very good phone too and is still up to date.If you have the money you can upgrade, not upgrading was just my opinion.
  15. OneByOneTwo
    Froyo Jul 2, 2018
    OneByOneTwo , Jul 2, 2018 :
    1. Camera
    - Huawei P20 Pro does better in low light shots, detail of pictures.
    - OnePlus 6 is only average at camera, some shots' colours are too fake
    Winner: Huawei P20 Pro
    2. Battery Life.
    - Huawei P20 Pro has a better battery life in various YouTube comparison tests. (A huge 4000mAh battery is built-in)
    - OnePlus 6 only has average battery life (3300mAh battery built-in)
    3. Performance
    - Huawei P20 Pro has a Kirin 970 chipset. Not the best performance.
    - OnePlus 6 has a Qualcomm Snapdragon 845 chipset with 6GB/8GB storage. One of the fastest phones in the Android world.
    Winner: OnePlus 6
    Total Points:
    Huawei P20 Pro - 2
    OnePlus 6 - 1
    If these are your only areas of usage, I will suggest that you buy Huawei P20 Pro.
  16. Hemac
    Gingerbread Jul 2, 2018
    Hemac , Jul 2, 2018 :
    Go for P20 for photos, battery and performance, but there is no ois in video mode, correct me if um wrong.
  17. V1527255369052
    V1527255369052 , Jul 2, 2018 :
    p20 pro is way more better than oneplus 6 in every aspect, some people will say oneplus has speed but you wont do speed test with other phone, right? so day yo day use you wont feel any difference, battery sucks in oneplus 6.
    so go for p20 pro.
    p.s. i didnt mention anything about camera because you just simply cant compare p20 pro camera with oneplus 6. p20 pro camera is league ahead
    malidan and G_Ahamed_Sahadh_vjee like this.
  18. DARTH 007
    KitKat Jul 2, 2018
    it's like comparing 2 mediocre phones pretending to be the very best.
    it's like a wolf in lions clothing.
    never can be a lion though
  19. G_Ahamed_Sahadh_vjee
    Froyo Jul 6, 2018
    G_Ahamed_Sahadh_vjee , Jul 6, 2018 :
    friend, which phone are you refering to?
    thanks mates for your thoughts :)
    Great info, much appreciated :)
    OIS only for 720p .. thanks for your thoughts :)
    it seems to be true :)
    ok mate :)
  20. MKT_IRFAN3735
    Jelly Bean Jul 6, 2018
    MKT_IRFAN3735 , Jul 6, 2018 :
    I suggest you can take lead on OnePlus 6 coz of good UI not a crappy EMUI and Oneplus will ALWAYS for customer support Honor [e]1f44e[/e] and OTA updates Oneplus is good at providing updates, ATLAST go with Oneplus or else use Nokia 1100[e]1f602[/e]
