oneplus 6 pin change problem
  1. shrutiii09 Cupcake Aug 21, 2018
    shrutiii09, Aug 21, 2018 :
    i changed the pin to my phone and it was successful and then it shows incorrect after one try. I switched off and switched on my phone and now it won't even show me anything on the screen. I cannot access anything anymore. how and what do I do now?
  2. W1nd Gingerbread Aug 21, 2018
    W1nd, Aug 21, 2018 :
    hmm .. sometime it happens when touch doesn't register correctly. now there os no other way around .
    you have to factory reset your phone buy recovery menu .
    just power off your phone . than hold power and volume up button together for few seconds.
    there you will asking for pin and right side corner forget password option .. you click it and you gonna loose all your data and phone gonna factory reset .
  3. Shuller Jelly Bean Aug 21, 2018
  4. tweetinginabox Jelly Bean Aug 21, 2018
    tweetinginabox, Aug 21, 2018 :
    it would be even more serious if it locked him out of recovery altogether as other devices can if you forget it have the incorrect pin lock.
